1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: CSS BOY rotated XY Graph
To: John Dobbins <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Wed, 09 Jun 2010 11:58:19 -0400
Please select CSS menu: CSS->Display->Install OPI Examples, then you will have BOY Examples installed in your workspace.
Open /BOY Examples/widgets/2_6_2_IntensityGraph.opi and you will see the example. The vertical profile can be done by simply exchanging X PV and Y PV. Of course, you also need to set the correct buffer size and set "Chronological" and "Concatenate Data" to false.
Xihui
-----Original Message-----
Sent: Wednesday, June 09, 2010 11:21 AM
To: EPICS Tech-Talk
Subject: CSS BOY rotated XY Graph
I am trying to produce a CSS BOY display for a video camera showing the video and horizontal and vertical profiles. The one part I am stuck on now is trying to produce a XY Graph for the vertical profile. See attached image. I would like the vertical profile data to be plotted rotated 90 degrees but can't figure out how to do this.
I've seen pictures of such BOY screens. Can someone post an example?
John Dobbins
Lab for Elementary Particle Physics
Cornell University
CSS BOY rotated XY Graph John Dobbins
Prev: RE: CSS BOY XY Graph Chen, Xihui
Next: unsigned long record value Patrick Thomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: CSS BOY rotated XY Graph John Dobbins
