1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS BOY XY Graph
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 09 Jun 2010 08:56:37 -0400
OK. I got the XY graph to work (I needed to adjust trace buffer size).
At present the graph retrieves and plots .NELM values from the waveform. Is it possible to make it retrieve and plot .NORD values (or some other number of points) from waveform instead?
John Dobbins
John Dobbins wrote:
In MEDM or EDM one can create an XY graph and assign a PV to just the Y-axis. When I try to do the same in CSS BOY no trace appears (unless I also assign an X-axis PV). Is there a way to get the behavior familiar from MEDM/EDM?
John Dobbins
Lab for Elementary Particle Physics
Cornell University
RE: CSS BOY XY Graph Chen, Xihui
CSS BOY XY Graph John Dobbins
Prev: Re: hypertable archiver Jack
Next: CSS BOY rotated XY Graph John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: CSS BOY XY Graph John Dobbins
Next: RE: CSS BOY XY Graph Chen, Xihui
