1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CA Lab - New interface between LabVIEW™ and EPICS
To: Carsten Winkler <[email protected]>
Cc: [email protected]
Date: Wed, 09 Jun 2010 08:22:38 +0200
Dear Carsten,
I'm certainly interested to test that under Linux, what is your planning to that ?
What is the maximum number of PVs monitored, tested up to now ?
- Mauro
Mauro Giacchini
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
V.le dell’Universita', 2
35020 LEGNARO (PD) – ITALY
Tel. +39.049.8068558
Fax. +39.049.641925
EPICS _at_ LNL http://www.lnl.infn.it/~epics/
Carsten Winkler wrote:
What is "CA Lab"?
"CA Lab" is a user-friendly, lightweight and high performance interface between LabVIEW™ and EPICS.
This project uses proven EPICS BASE libraries (V3.14.11), a "CA Lab"-library and 3 "CA Lab"-VIs.
Why another EPICS<->LabVIEW™ interface?
LabVIEW™ needs only this simple interface to connect to any EPICS variable.
You DON'T need OPC nor Shared Memory Variables nor Network variables nor NI IO Service nor any other service to get and set EPICS variables in your VI.
It's not necessary to create a LabVIEW™ project to use this interface.
No problem to create an executable of your VI and to distribute it.
EPICS time stamp, status and severity are bound to resulting values.
Epics variables are available as cluster:
* Values as string array
* Values as double array
* Size of array
* Type of received data
* Status of values as string
* Status of values as integer
* Severity of values as string
* Severity of values as integer
* EPICS time stamp as string
* EPICS time stamp as integer
"CA Lab" is open source and works with all LabVIEW™ versions from 7.1 to 2009. It has been tested under Windows XP® and Windows 7®.
It should be no problem to compile source code under Linux.
For more information about CA Lab, please see our page http://www-csr.bessy.de/control/SoftDist/CA_Lab/
CA Lab - New interface between LabVIEW? and EPICS Carsten Winkler
Prev: Re: EDM macro Thomas Birke
Next: ChannelArchiver 2GB Index File Size Limit james.rowland
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: CA Lab - New interface between LabVIEW? and EPICS Carsten Winkler
Next: CSS BOY XY Graph John Dobbins
