1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Waveform Record Device Support
To: <[email protected]>
Date: Mon, 7 Jun 2010 10:06:52 +0100
Hi All,
I am integrating a turn-by-turn BPM system into EPICS and would like to
store the raw BPM pickup data in a waveform record.  Due to the nature
of the system, each run can result in a different number of samples for
each BPM pickup, so the array size is unknown in advance and could
potentially be different every run.
Is it possible to resize the number of waveform record elements in my
device support, or do I have to size the waveform record in advance for
the maximum number of samples that could be expected.  Most of the
examples of waveform device support I see read the nelm field and return
this fixed amount of data via the records bptr.
Graham
Scanned by iCritical.
Re: Waveform Record Device Support Dirk Zimoch
Re: Waveform Record Device Support emmanuel_mayssat
Re: Waveform Record Device Support Till Straumann
Prev: EDM Related Display Question Szalata, Zenon M.
Next: Re: Waveform Record Device Support Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
