Hi Zen
I seem to recall using some SBC that had programmable auxiliary clock(s)
one could programme to trigger at predefined rate: maybe your h/w has
that capability.
"sysClkRateSet(5000)" from vxWorks, indeed be very cautious !
Matthieu
On 06/03/10 17:35, Ron Sluiter wrote:
Addressing the limits of the VxWorks system clock....
With VxWorks 5.5, the upper limit on the system clock is set by the
SYS_CLK_RATE_MAX parameter in the <WIND_BASE>/target/config/mv<cpubrd>.h
file. For a MVME5100 board, the default limit is 5000 Hz (200 us). The
default system clock rate to 60 Hz. You can change the system clock
(before EPICS iocInit is called and only with EPICS R3.14 and above)
with a "sysClkRateSet(5000)" call. Of course, setting the system clock
to 5000 Hz is going to cause a timer interrupt every 200 us and create a
lot of overhead; use with caution.
Ron
Eric Norum wrote:
The epicsTimer quantum is that of the vxWorks system clock and is
almost certainly too large for this to be accomplished.
If you have a hardware timer available you could use it to generate
interrupts and perform the timing that way.
If you need really precise timing you might have to move all this out
to custom hardware.
On Jun 3, 2010, at 1:15 PM, Szalata, Zenon M. wrote:
I have a VME system, which is external trigger driven. I wrote a
device driver for one of the modules in the VME crate. The device
driver is so far OSI. I am using EPICS R3.14.11 and vxWorks 6.6.
In my device driver, I need to execute a command a few hundred of
micro seconds after the trigger. The device driver responds to the
trigger, by queuing a call back routine. I would like to setup in the
trigger handling call back routine another call back routine to be
called a few hundred microseconds later. I don't want to call vxWorks
routines directly. Looking through "EPICS: Input/Output Controller
Application Developer's Guide", it seems to me that epicsTimer is a
good candidate. Unfortunately, as it is for me, this guide is very
good once I know what I am doing. Since I have not used epicsTimer
before, the description in the guide is not explicit enough to be
useful.
I would greatly appreciate if someone sent me an example of how to
accomplish my goal in a device driver written in C.
Thank you,
Zen
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- RE: epicsTimer Szalata, Zenon M.
- epicsTimer Szalata, Zenon M.
- Re: epicsTimer Eric Norum
- Re: epicsTimer Ron Sluiter
<2010>
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
