1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: state machine programming
To: Ralph Lange <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Sun, 30 May 2010 14:10:51 -0700
> Through exec() calls a state machine can call any program or script
> written in any language on your system. You find that too low level?!
> Could you explain your definition of high level in that context?
end_stations_protocol:
  align sample with beam
  detector_acquire_image
  move_grid
  rotate_sample
  move_grid
  insert_sample_3
  collect_data_set
  remove_sample_from_field_of view
  send_email_to_experimenter
  move_data_files_to_long_term_file_server
each command is drag-and-dropped by the experimenter (not a programmer)
sequence can be changed by the experimenter function of what he wants to do
He should be able to work independently of programmers
synchroton-turn-on:
  turn_on_injector_laser
  warm_up_modulator_1
  condition_magnet
  insert_screen_2
  start_injector_feedback
Of course, each of those states can be further broken down and later refined
(I can easily see a state machine with 500+ states)
interpreted languages are better, no compilation needed
+ you can program a sequence on the fly (no downtime required)
Can your sequencer to do that?
> I probably am over-interpreting your mails, but I do get the impression
> that you possibly are shopping for interesting solutions while not
> having nailed down your requirements, which IMHO should be done as early
> as possible in the process.
For a software tool like a sequencer, I always consider flexibility ... a requirement.
Emmanuel
Re: state machine programming Ralph Lange
state machine programming emmanuel_mayssat
Re: state machine programming Ben Franksen
Re: state machine programming emmanuel_mayssat
Prev: Re: state machine programming Eric Norum
Next: Re: state machine programming Claude Saunders
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: state machine programming Ralph Lange
