All polemics aside - I do know what the current situation is and
that there are historic and maybe technical reasons (which can
always be overcome) for this situation.
Nevertheless, I do understand Matt's point of view. It is simply
not very user-friendly that you have to think what the largest
array may be you want to transfer and to have to set
EPICS_CA_MAX_ARRAY_BYTES
on both, the IOC and the client side, IIRC before you start either.
An IOC application designer is not necessarily aware of the
correct size and when the client-side user finds out that
he/she cannot transfer, learns about and sets EPICS_CA_MAX_ARRAY_BYTES
he/she has then to go back and educate the IOC-app designer
who then has to set the variable and eventually reboot the IOC.
If this sequence happens a few times then the annoyed
engineer will simply set EPICS_CA_MAX_ARRAY_BYTES to
some large number everywhere
IMHO it would be desirable to do away with EPICS_CA_MAX_ARRAY_BYTES
and implement some better, dynamic buffer management scheme.
-- Till
On 05/28/2010 09:21 AM, Ralph Lange wrote:
Hi Matt,
as Andrew covered the technical aspects and pointed out solutions, I
just want to clarify:
In your original mail, you sounded as you were assuming that the
environment variable EPICS_CA_MAX_ARRAY_BYTES was introduced with the
intention of limiting the size of arrays that CA is able to handle.
My statement was: No, it was the other way round. The limitation had
been there from the beginning. The environment variable was introduced
with the intention to overcome this limitation and allow CA to handle
larger arrays.
Sorry for being not clear enough in the first place.
Cheers,
Ralph
On Thu 27 May 2010 21:25:01 Matt Newville wrote:
Hi Ralph,
Thanks for the reply.
On Wed, May 26, 2010 at 11:27 AM, Ralph Lange <[email protected]>
wrote:
Hi Matt,
nope, it's the other way round:
Maybe I'm still not understanding completely because I don't see much
difference between your explanation and what I said,
- Re: labCA and EPICS_CA_MAX_ARRAY_BYTES J. Lewis Muir
- labCA and EPICS_CA_MAX_ARRAY_BYTES John Dobbins
- Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Till Straumann
- Re: labCA and EPICS_CA_MAX_ARRAY_BYTES emmanuel_mayssat
- RE: labCA and EPICS_CA_MAX_ARRAY_BYTES Mark Rivers
- Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Matt Newville
- Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Ralph Lange
Fall Epics Meeting location? Jane Richards
<2010>
<2010>
