1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: building areaDetector firewire support on Windows
To: "John Dobbins" <[email protected]>, "EPICS Tech-Talk" <[email protected]>
Date: Thu, 27 May 2010 10:48:42 -0500
John,
I am not sure that the Firewire driver actually needs the MFC SDK.  What happens if you comment out the include of afxwin.h?  The Roper driver probably does need MFC, but Firewire may not.
Sent: Thu 5/27/2010 10:29 AM
To: EPICS Tech-Talk
Subject: building areaDetector firewire support on Windows
All,
I wen to build areaDetector with Microsoft Visual Express edition but in the directory firewireWinSrc I run into  the error
C:\USER_LOCAL\epics\support\areaDetector-1-6\ADApp\firewireWinSrc>make
make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
make[1]: Entering directory `C:/USER_LOCAL/epics/support/areaDetector-1-6/ADApp/firewireWinSrc/O.win32-x86'
make[1]: *** No rule to make target `../../../include/os/WIN32/afxwin.h', needed
 by `firewireWinDCAM.obj'.  Stop.
make[1]: Leaving directory `C:/USER_LOCAL/epics/support/areaDetector-1-6/ADApp/firewireWinSrc/O.win32-x86'
make: *** [install.win32-x86] Error 2
Which as far as I can tell is because the Express Edition does not include the MFC SDK. I don't think MinGW does either.
I had previously used Visual Studio 2005 so I didn't run into this problem.
Ideas?
John Dobbins
Laboratory for Elementary Particle Physics
Cornell University
building areaDetector firewire support on Windows John Dobbins
Prev: building areaDetector firewire support on Windows John Dobbins
Next: Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: EPICS wiki is down Benjamin Franksen
