1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: a waveform record question
To: "Andrew Johnson" <[email protected]>, <[email protected]>
Cc: fenggangbian <[email protected]>
Date: Thu, 27 May 2010 08:59:03 -0500
For this application this won't work, because the waveform in the second IOC is using asyn device support (with areaDetector), so it's INP field is already in use for asyn.  One way to do this would be with an asub record on either IOC, reading from the waveform that LabView controls, and writing to the areaDetector waveform in the second IOC.
But a better solution might be to change how you are interfacing EPICS to LabView.  You are using the shared memory device support.  Why not change to using the LabView Channel Access interface?  Then you can directly write the waveform to the second IOC from LabView.
From: [email protected] on behalf of Andrew Johnson
Sent: Thu 5/27/2010 7:44 AM
To: [email protected]
Cc: fenggangbian
Subject: Re: a waveform record question
On Wednesday 26 May 2010 09:33:33 fenggangbian wrote:
> Hi,
>    Now I am working a program using LabView talk to EPICS by shared
> memeory. LabView create a local softIOC ,firstly LabView talk to the soft
> ioc and use the softioc to connect other outside ioc. I may already use
> LabView to connect soft IOC. I encounter a question that how to write a
> waveform PV in soft IOC to other waveform PV in anther IOC. The support
> record of array in the soft IOC only have subArray record and waveform
> record. Such as aao etc record don't support.
The waveform record has soft support using the INP link, so your second IOC
could read the waveform data from the soft IOC.  If you mark the input link as
CP it will process that record automatically whenever the source record posts
a monitor on value update.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
a waveform record question fenggangbian
Re: a waveform record question Andrew Johnson
Prev: Re: CA web service Re: iPhone port Ralph Lange
Next: building areaDetector firewire support on Windows John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: a waveform record question Andrew Johnson
Next: stream device formatting question Burkhard Kolb
