1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Epics 3.14.8: faulty registrar statement in dbd causes memPartAlloc error on vxWorks
To: [email protected]
Date: Thu, 27 May 2010 08:21:25 -0500
Hi Goetz,
On Thursday 27 May 2010 07:44:23 Goetz Pfeiffer wrote:
> I use Epics 3.14.8 for my application. I recently got rid of two of my
> sequencer programs due to various optimizations. But I still had a
> "registrar" statement in my dbd file, now for a module that no longer
> existed.
You should have seen a load failure complaining about missing symbols of the
form pvar_func_<routine> for each of your missing registrar routines.  Those
load failures should never be ignored, they indicate problems of this kind.
> I verified that any "registrar" statement for a non-existing module
> produces this error. But if you see this on the IOC console you have no
> idea whats wrong with your program. An error message like "invalid
> registrar [registrar-name]" would be much better.
> Does the newest Epics release still show this behavior and if it is so,
> are any plans to fix this ?
Please check whether you were getting those load errors or not.  The
idcp_registerRecordDeviceDriver() subroutine that gets generated from your
IOC's DBD file just calls every registrar function directly, it doesn't
currently have the names of those routines as strings.  It could detect this
case, but the load errors should be sufficient to tell you there's something
wrong.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: Epics 3.14.8: faulty registrar statement in dbd causes memPartAlloc error on vxWorks Goetz Pfeiffer
Prev: Re: a waveform record question Andrew Johnson
Next: Re: CA web service Re: iPhone port Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Epics 3.14.8: faulty registrar statement in dbd causes memPartAlloc error on vxWorks Goetz Pfeiffer
Next: Re: Epics 3.14.8: faulty registrar statement in dbd causes memPartAlloc error on vxWorks Goetz Pfeiffer
