1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: iPhone port
To: Ralph Lange <[email protected]>
Cc: “EPICS Tech-talk“ <[email protected]>
Date: Wed, 26 May 2010 09:30:48 -0400
Hi Ralph,
Possibly, but not as a plugin. It may work as a dedicated application that incorporates a web view. I'm not sure whether that would work.
For CAML, I want to abstract the CA source so it can be from a plugin or a web service. In either case, it will get data packaged in JSON. This should work fine for any modern browser including iPhone without the need for a plugin. For desktop browsers, the plugin would be optional. If the plugin is available it would be used and if not it would fall back to the web service.
best regards,
tom
On May 25, 2010, at 5:14 PM, Ralph Lange wrote:
> I knew it was just a matter of time until someone came up with this...
> Will the iPhone/iPod/iPad browser be able to run CAML?
> Ralph
> On Tue 25 May 2010 16:33:34 Pelaia II, Tom wrote:
>> Hi,
>> If anyone is interested, I have an iPhone port of the Channel Access ca and com libraries along with a port of the corresponding Objective-C framework.
>> This port works with the iPhone simulator. I don't have a developer certificate which allows me to test on an actual device.
>> best regards,
>> tom
CA web service Re: iPhone port Kasemir, Kay
iPhone port Pelaia II, Tom
Re: iPhone port Ralph Lange
Prev: Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Till Straumann
Next: Re: iPhone port Robert Soliday
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: iPhone port Ralph Lange
Next: CA web service Re: iPhone port Kasemir, Kay
