1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: labCA and EPICS_CA_MAX_ARRAY_BYTES
To: John Dobbins <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 25 May 2010 10:27:12 -0500
On 05/25/2010 09:55 AM, John Dobbins wrote:
Is it possible to use labCA to retrieve arrays larger than 16K?
Yes - I routinely use that. You have to make sure EPICS_CA_MAX_ARRAY_BYTES is set in the environment *before* you start matlab or scilab (RTM).
On the IOC, too, you need EPICS_CA_MAX_ARRAY_BYTES but
since you tested with caget that's obviously set up correctly.
-- Till
I have EPICS_CA_MAX_ARRAY_BYTES set to a large number and verified that caget will retrieve a large array but labCA 3.1 returns an error.
data= lcaGet('IBLEMS01_data', 120000);
Initializing labCA Release '$Name: labca_3_1 $'...
Author: Till Straumann <[email protected]>
??? Error using ==> lcaGet
multi_ezca_get - ezcaGetWithStatus(): get_callback() : The requested data transfer is greater than
John Dobbins
Cornell University
Laboratory for Elementary-Particle Physics
Re: labCA and EPICS_CA_MAX_ARRAY_BYTES emmanuel_mayssat
labCA and EPICS_CA_MAX_ARRAY_BYTES John Dobbins
Prev: RE: labCA and EPICS_CA_MAX_ARRAY_BYTES Allison, Stephanie
Next: Re: RE: PV's element count differs though CA gateway Carl Schumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: labCA and EPICS_CA_MAX_ARRAY_BYTES John Dobbins
Next: Re: labCA and EPICS_CA_MAX_ARRAY_BYTES emmanuel_mayssat
