Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017
Subject: RE: How to force a record to generate a monitor
To: <zms@slac.stanford.edu>, <tech-talk@aps.anl.gov>
Date: Mon, 24 May 2010 10:04:18 +0100
I believe that EDM only does a get with the DBR_CTRL_* dbr type, then
monitors using the DBR_STS_* type. This means that EDM doesn't receive
updates when the menu strings update. I get round this by using a "menu
mux" with its pv name pointing to the record in question. This widget
has a hook into the screen redraw function that causes the entire screen
to redraw when the record updates.
Tom Cobb,
Diamond Light Source Ltd.
Diamond House
Harwell Science and Innovation Campus
Didcot
Oxfordshire
OX11 0DE
Tel +44 (0) 1235 778582
> -----Original Message-----
> From: tech-talk-bounces@aps.anl.gov
> [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Szalata, Zenon M.
> Sent: 24 May 2010 00:18
> To: TECHTALK Tech-Talk
> Subject: How to force a record to generate a monitor
> I am initializing a mbbo record with "menu" strings from my
> device driver.  This is done on demand and it works well.
> Unfortunately, the record does not issue a monitor when that
> is done so EDM does not get that the record now has new set
> of strings.  If I toggle EDM to edit then to execute it gets
> the new strings.
> How can I nudge the mbbo record from my device driver to
> issue a monitor?
> I have access to the records data structure.
> Any suggestions are welcome,
> Zen
How to force a record to generate a monitor Szalata, Zenon M.
Prev: How to force a record to generate a monitor Szalata, Zenon M.
Next: Re: genSub to aSub conversion Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017
Next: Re: How to force a record to generate a monitor Andrew Johnson
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
