1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Rogue process variables
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 21 May 2010 10:13:30 -0400
Thanks Mark,
with 3.14.10 I can see the numeric host address when I run cainfo on localhost, the name when I run it across the network. That is the behavior I would expect after the mentioned fix.
Then we'll just proceed with fingers crossed, and ask Emmanuel to use cainfo compiled with a recent version of base.
Cheers,
Ralph
On Fri 21 May 2010 9:59:27 Mark Rivers wrote:
Ralph,
I thought I saw it on 3.14.11, but I can't reproduce it. I do get a blank host name the first time I access a PV with an older version of cainfo built with 3.14.8.2.
Rogue process variables emmanuel_mayssat
RE: Rogue process variables Mark Rivers
Re: Rogue process variables Ralph Lange
Prev: RE: Rogue process variables Mark Rivers
Next: Re: Race conditions in SNL programs Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: genSub to aSub conversion emmanuel_mayssat
