Whooops, cainfo indeed *does* it.
> cainfo fred
fred
State: connected
Host: nsls2rlange.nsls2.bnl.gov:5064
Access: read, write
Data type: DBR_DOUBLE (native: DBF_DOUBLE)
Element count: 1
Note, though, that - depending on the performance of network, client and
host machines, and the DNS configuration and status - when Channel
Access does the connection callback, the host name may not be available yet.
cainfo waits for the connection callbacks, then calls ca_host_name() to
get the host name. If Channel Access returns an empty string, cainfo
prints it.
Doing "PV info" from a medm screen does basically the same thing, but
pointing the mouse at the widget and doing the right click leaves enough
time for CA and DNS to have the host name ready when medm wants it.
See https://bugs.launchpad.net/epics-base/+bug/541342 for an explanation
and the fix that was applied to 3.14.10
(Mark, do you still see this on 3.14.10 or later? If so, you probably
should reopen the issue.)
Cheers,
Ralph
On Thu 20 May 2010 20:20:26 Mark Rivers wrote:
Whoops, cainfo does not do it.
But make an medm screen with a widget for that PV, and then right click
and select "PV info".
That will give you the name of the IOC machine.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Thursday, May 20, 2010 7:16 PM
To: [email protected]; EPICS tech-talk
Subject: RE: Rogue process variables
base/bin/linux-x86/cainfo PVName
[email protected]
Sent: Thursday, May 20, 2010 7:15 PM
To: EPICS tech-talk
Subject: Rogue process variables
Hello all,
I have an IOC running somewhere on the network.
I can see the PV, but cannot find the ioc process.
Is there a way from a terminal to find out on which computer/port
PVs are available?
- RE: Rogue process variables Mark Rivers
- Rogue process variables emmanuel_mayssat
RE: Race conditions in SNL programs Mark Rivers
<2010>
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
