1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Race conditions in SNL programs
To: [email protected]
Date: Fri, 21 May 2010 14:01:27 +0200
On Friday 21 May 2010, Andrew Johnson wrote:
> On Thursday 20 May 2010 17:53:04 Benjamin Franksen wrote:
> > This bug must have been in the sequencer for a long, long time,
> > probably right from the beginning.
> I'm not convinced it's quite as bad as you think; I suspect it derives
>  from R3.14.x when Jeff introduced the ca_enable_preemptive_callback
>  option.  Before this time the CA library never got a chance to process
>  network messages unless you called it using ca_pend_event() or
>  ca_pend_io() so the callbacks would only run when the thread was inside
>  the CA library.
Unfortunately, pre-3.14 versions are affected, too, see below.
> Hmm, that doesn't necessarily work with multiple state sets though, I
>  wonder if CA supported sharing CA contexts back then?
It did, this is what the ca_import routine was for.
You are right that if you use one single task and
ca_disable_preemptive_callback (or, equivalently, the old
ca_task_initialize), then there is no problem. However, even the old 1.9.x
sequencer releases use an extra auxiliary task to initialize CA, and a
separate task for each state set taht calls ca_import. The auxiliary task is
the only place where ca_pend_event is called. This means all callbacks will
be executed in the task context of the auxiliary task, and (I checked it)
there are no locks taken when the callback copies the data into the program
variable.
So, the only difference is that in the old versions it is the sequencer's
own task, while in later versions it is a (hidden) CA internal task.
Cheers
Ben
Re: Race conditions in SNL programs Dirk Zimoch
Race conditions in SNL programs Benjamin Franksen
Re: Race conditions in SNL programs Andrew Johnson
Prev: Re: Race conditions in SNL programs Andrew Johnson
Next: Re: Race conditions in SNL programs Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
