On Mittwoch, 19. Mai 2010, Davidsaver, Michael wrote: The usual way, lots of trial, and lots of error :) What about all the other cross-compiler targets and their specific configuration? While I've had many frustrations with it, I must say that this is were the Base build system helped me. Mostly this just worked. Of course I only cross-build RTEMS, not other host targets. There is much less chance of shared library dependency problems when you don't have shared libraries! I mean, how do I configure a debian package for epics base in the first place? Set PATH, LD_LIBRARY_PATH in the environment and patch the build system to avoid linking with -rpath. Among the debian packaging tools is the Lintian utility which analyzes the build package for common mistakes. After ~12 years it knows about a lot of problems. Will there be some /etc/epics.conf? That is on hold until Andrew and I come to an agreement on how this should be implemented. Until then the EPICS_* environment variables are it. OTOH, doesn't EPICS At present it actually doesn't. These are runtime parameters related to channel access and IOCs. Thankfully neither are needed during the build. Michael
| ANJ, 02 Sep 2010 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
