Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017
Subject: Re: MEDM Panels disappeared frequently on Fedora Code 8 32 bit version...
To: Ramu Denduluri <ramu_denduluri@lynceantech.com>
Cc: tech-talk@aps.anl.gov
Date: Fri, 14 May 2010 09:29:37 -0500
I would check to see if your session is setup to logout automatically after a certain period of time. If you use tcsh run:
echo $autologout
If you use bash:
echo $TMOUT
--Bob
Ramu Denduluri wrote:
Hi All,
Following are different versions of EPICS Base and MEDM for which the MEDM panels getting disappeared every few hours on Fedora Core 8 32 bit operating system. There are quite a few MEDM panels that we are using and all of those panels are getting disappeared, which is causing lot of inconvenience.
1) EPICS Base 3.14.11 with MEDM versions 3.1.1, 3.1.2.1, and 3.1.4
2) EPICS Base 3.14.9 with MEDM versions 3.1.1, 3.1.2.1, and 3.1.4
3) EPICS Base 3.14.6 with MEDM version 3.0.3, which was working version on Redhat 8. Last year, we migrated all our software to Fedora 8 32 bit version.
Could anyone point me to the correct versions of EPICS Base and MEDM, which works fine.
Best Regards,
Ramu
Striptool crashes for Fedora 11 64 bit version... Ramu Denduluri
MEDM Panels disappeared frequently on Fedora Code 8 32 bit version... Ramu Denduluri
Prev: RE: cygwin 1.7 compatibility Mark Rivers
Next: RE: cygwin 1.7 compatibility Ru Igarashi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017
Prev: RE: MEDM Panels disappeared frequently on Fedora Code 8 32 bit version... Mark Rivers
Next: RE: Striptool crashes for Fedora 11 64 bit version... Kevin Anderson
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
