1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: cygwin 1.7 compatibility
To: "Ru Igarashi" <[email protected]>, <[email protected]>
Date: Fri, 14 May 2010 05:55:48 -0500
Hi Ru,
What hardware are you talking to?  I think you need to figure out which thread or threads is hanging.  When it hangs what are the symptoms? Is channel access working either direction?  I think I am running Cygwin 1.7, but I'll check when I get to work.  I have not heard of the problem you are describing, and we use Cygwin quite a bit.
Sent: Thu 5/13/2010 10:17 PM
To: [email protected]
Subject: cygwin 1.7 compatibility
I just ran into a problem running dxp 2-10 and EPICS 3.14.9 compiled
on a Windows PC running cygwin 1.7 (first release Dec 2009).  The app
runs fine on the same machine running cygwin 1.5.  The app runs but
after configuring the hardware, then sending or receiving an unknown
number of PV updates, it refuses further updating, and as far as I
can tell it just idles. SoftIoc works fine with my simple tests.  I
haven't had time to run proper diagnostics, opting to just revert and
get the users going. I'm still digging through the Tech Talk archives,
but I haven't found any mention of this, so far.  I was just wondering
if this has already been discussed or dealt with (e.g. perhaps EPICS
3.14.10+ has dealt with it?).
ru
Ru Igarashi                    Software & Instrumentation Specialist
e-mail: [email protected]   Canadian Light Source
ph:306 657 3751                University of Saskatchewan
fax: 306 657 3535              Saskatoon SK S7N 0X4
RE: cygwin 1.7 compatibility Mark Rivers
RE: cygwin 1.7 compatibility Ru Igarashi
Prev: Re: No monitor refresh Hinko Kocevar
Next: RE: No monitor refresh Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: cygwin 1.7 compatibility Wang Xiaoqiang
Next: RE: cygwin 1.7 compatibility Mark Rivers
