1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: No monitor refresh
Cc: [email protected]
Date: Tue, 11 May 2010 18:07:57 +0200
Hello Mark,
On 05/11/10 16:55, Mark Rivers wrote:
> As Ralph pointed out, you have set SCAN=I/O Intr.  For this to work your
> asyn port driver (called ENV in your case) must do callbacks to device
> support when it receives a new value.  Does this driver do so?
Yes it does. I can confirm that the value indeed does change in lower
levels. Even caput response is showing new value. Also when (re)starting
the camonitor the first value shown is always prompt and correct!
> You can get information about this by typing
> asynReport 10 ENV
Here is the output - I've stripped 100 or more records not to clutter
the post.
epics> asynReport 10 ENV
ENV multiDevice:Yes canBlock:No autoConnect:Yes
    enabled:Yes connected:Yes numberConnects 1
    nDevices 89 nQueued 0 blocked:No
    asynManagerLock:No synchronousLock:No
    exceptionActive:No exceptionUsers 0 exceptionNotifys 0
    interposeInterfaceList
        asynOctet pinterface 0x40086024 drvPvt 0x1b4c8
    interfaceList
        asynCommon pinterface 0x4003c548 drvPvt 0x2b710
        asynInt32 pinterface 0x4003c9ac drvPvt 0x2b710
        asynUInt32Digital pinterface 0x4003c990 drvPvt 0x2b710
        asynOctet pinterface 0x4003c964 drvPvt 0x2b710
    addr 725 autoConnect Yes enabled Yes connected Yes exceptionActive No
    exceptionActive No exceptionUsers 0 exceptionNotifys 0
    blocked No
  Port: ENV
  lastAddress=0
epics>
> That should show you what asyn clients (e.g. device support) have
> registered for callbacks on which interfaces.
> What happens if you change SCAN to "1 second"?
Will try!
Thank you for the help!
Best regards,
Hinko
> Mark
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Hinko Kocevar
> Sent: Tuesday, May 11, 2010 9:07 AM
> To: [email protected]
> Hello Ralph,
> On 05/11/10 15:21, Ralph Lange wrote:
>> Hello Hinko,
>> what EPICS versions are you using for client and IOC?
> IOC and client use 3.14.10 EPICS base version.
>> Can you show a dump (dbpr <name>, 4) of the record that you are
>> connecting to?
> Sure, here it is:
> epics> dbpr LIBERA01:ENV:ENV_AGC_MONITOR 4
> ACKS: NO_ALARM      ACKT: YES           ASG:                ASP:
> 0x00000000
> BKPT: 0x00          COSV: NO_ALARM      DESC: AGC           DISA: 0
> DISP: 0             DISS: NO_ALARM      DISV: 1             DPVT:
> 0x50c72c00
> DSET: 0x7c620840    DTYP: asynInt32     EIST:               EISV:
> NO_ALARM
> EIVL: 0x0           ELST:               ELSV: NO_ALARM      ELVL: 0x0
> EVNT: 0             FFST:               FFSV: NO_ALARM      FFVL: 0x0
> FLNK:CONSTANT 0     FRST:               FRSV: NO_ALARM      FRVL: 0x0
> FTST:               FTSV: NO_ALARM      FTVL: 0x0           FVST:
> FVSV: NO_ALARM      FVVL: 0x0           INP:INST_IO @asyn(ENV, 725, 1.0)
> LALM: 1             LCNT: 0             LSET: 0xe8752e00    MASK:
> 4294967295
> MLIS: 0x38d0320060d0320003000000        MLOK: 0x28700b00    MLST: 1
> NAME: LIBERA01:ENV:ENV_AGC_MONITOR      NIST:               NISV:
> NO_ALARM
> NIVL: 0x0           NOBT: 0             NSEV: NO_ALARM      NSTA:
> NO_ALARM
> ONST: AUTO          ONSV: NO_ALARM      ONVL: 0x1           ORAW: 1
> PACT: 0             PHAS: 0             PINI: YES           PPN:
> 0x00000000
> PPNR: 0x00000000    PRIO: LOW           PROC: 0             PUTF: 0
> RDES: 0xa8a10300    RPRO: 0             RSET: 0x34b70a40    RVAL: 1
> SCAN: I/O Intr      SDEF: 1             SDIS:CONSTANT       SEVR:
> NO_ALARM
> SHFT: 0             SIML:CONSTANT       SIMM: NO            SIMS:
> NO_ALARM
> SIOL:CONSTANT       SPVT: 0x388a2f00    STAT: NO_ALARM      SVAL: 0
> SVST:               SVSV: NO_ALARM      SVVL: 0x0           SXST:
> SXSV: NO_ALARM      SXVL: 0x0           TEST:               TESV:
> NO_ALARM
> TEVL: 0x0           THST:               THSV: NO_ALARM      THVL: 0x0
> TIME: 2010-05-11 11:18:40.100440000     TPRO: 0             TSE: 0
> TSEL:CONSTANT       TTST:               TTSV: NO_ALARM      TTVL: 0x0
> TVST:               TVSV: NO_ALARM      TVVL: 0x0           TWST:
> TWSV: NO_ALARM      TWVL: 0x0           UDF: 0              UNSV:
> NO_ALARM
> VAL: 1              ZRST: MANUAL        ZRSV: NO_ALARM      ZRVL: 0x0
>> What field of that record are you connecting to?
> I did no specify any field - so it is VAL, I guess by default.
> Thank you!
> Regards,
> Hinko
>> Regards,
>> Ralph
>> On Tue 11 May 2010 6:26:48 Hinko Kocevar wrote:
>>> Hi all,
>>> I'm experiencing some strange behavior when using camonitor against
> an
>>> EPICS IOC.
>>> For some reason a CA_PROTO_EVENT_ADD response from IOC to CA client
> does
>>> not arrive, or arrives several minutes later after the PV value has
>>> changed. Note that first CA_PROTO_EVENT_ADD response is seen always,
>>> only latter CA_PROTO_EVENT_ADD responses do not arrive (or arrive
> late)?!
>>> This behavior is not seen always - sometimes the IOC would promptly
>>> respond with CA_PROTO_EVENT_ADD response when needed.
>>> I can see the CA_PROTO_ECHO requests/responses fine on the same
>>> camonitor channel link, only CA_PROTO_EVENT_ADD response is not seen.
>>> Inspecting the IOC I can see that the value did change (on lower
> levels)
>>> and caput response is also valid - updated with new value.
>>> I've ruled out the network problems, since the issue is raised even
> when
>>> using cross-over cable to communicate with the IOC. Actually even I
>>> update the value in the IOC shell, the camonitor is not refreshed!!
>>> Has someone experienced something similar?
>>> Are there some conditions that need to fulfilled in order for IOC to
>>> send a subsequent CA_PROTO_EVENT_ADD response(s)?
>>> TIA & HAND,
>>> Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
RE: No monitor refresh Mark Rivers
Re: No monitor refresh Ralph Lange
Re: No monitor refresh Hinko Kocevar
Prev: Re: No monitor refresh Hinko Kocevar
Next: RE: No monitor refresh Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: No monitor refresh Mark Rivers
