1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: [Request of tech-support] Error in compiling EPICS 3.14.8.2 base with dbCommon.h
To: [email protected]
Date: Fri, 7 May 2010 11:52:34 +0900
While I am trying to compile EPICS base R3.14.8.2, I got the following error.
-----------------[From here]----------------
Installing generated generic include file
/usr/local/epics/R3.14.8.2/base/include/menuSimm.h
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I..
-I/usr/local/epics/R3.14.8.2/base/include/os/Linux
-I/usr/local/epics/R3.14.8.2/base/include         ../dbLock.c
In file included from ../dbLock.c:62:
/usr/local/epics/R3.14.8.2/base/include/dbCommon.h:45: error: expected
specifier-qualifier-list before âepicsTimeStampâ
make[3]: *** [dbLock.o] error 1
make[3]: Leaving directory `/usr/local/src/base-3.14.8.2/src/db/O.linux-x86'
make[2]: *** [install.linux-x86] error 2
make[2]: Leaving directory `/usr/local/src/base-3.14.8.2/src/db'
make[1]: *** [db.install] error 2
make[1]: Leaving directory `/usr/local/src/base-3.14.8.2/src'
make: *** [src.install] error 2
[root@******* base-3.14.8.2]#
----------------[End of error]-------------------------
I changed just INSTALL_LOCATION to /usr/local/epics/R3.14.8.2/base and
nothing is changed in configuration files. The value of
EPICS_HOST_ARCH is linux-x86 and I am using CentOS 5.4 with kernel
[root@******* base-3.14.8.2]# uname -a
Linux ******************** 2.6.18-164.15.1.el5xen #1 SMP Wed Mar 17
12:53:17 EDT 2010 i686 i686 i386 GNU/Linux
Would you review the error and tell me what I should do to solve it?
Thank you in advance.
Best regards,
Jincheol Kim.
   "Advancement of Science
		   with Innovation of Advanced Computing Technology"
   Jincheol B. Kim, Ph. D.
   Research Professor
   Center for Fusion Plasma Diagnostics
          and Steady State Operation Research,
   Department of Physics, POSTECH
   San 31, Hyoja-dong, Nam-gu
   Pohang, Kyungbuk 790-784
   Republic of Korea
   Tel: +82 54 279 5849		   FAX: +82 54 279 3099
   Mobile: +82 10 2713 7593	   E-Mail: [email protected]
				  	   [email protected]
Re: [Request of tech-support] Error in compiling EPICS 3.14.8.2 base with dbCommon.h J. Lewis Muir
Prev: RE: epicsEvent::invalidSemaphore exception in timerQueue Jeff Hill
Next: Re: [Request of tech-support] Error in compiling EPICS 3.14.8.2 base with dbCommon.h J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
