Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017
Subject: Re: Dump record fields into a text file
To: tech-talk@aps.anl.gov
Date: Tue, 04 May 2010 12:09:05 +0900
(10/04/30 7:24), Andrew Johnson wrote:
> On Thursday 29 April 2010 17:07:35 emmanuel_mayssat@lynceantech.com wrote:
>> Is there a way to dump the value of records into a text file?
>> i.e. dump the value of the PREC,EGU,DTYP,DESC fields of all records?
>> From the ioc shell:
>      dbl * "PREC EGU DTYP DESC">  file.txt
> You'll have to adjust that slightly (double-quote the asterisk and add a comma
> between the arguments) if you're on vxWorks.
> HTH,
> - Andrew
dbDumpRecord command on IOCsh can be also used, although it may give you
more data than you need.
epics>dbDumpRecord >out.db
dbStaticLib (or dbStaticLib module for Python) can be used to handle db
files.
Noboru Yamamoto
J-PARC control group
J-PARC center, JAEA & KEK
JAPAN
Dump record fields into a text file emmanuel_mayssat
Re: Dump record fields into a text file Andrew Johnson
Prev: PCaPAC 2010 - Second call for abstracts Elder Matias
Next: VxWorks Tornado 5.5 Konstantinos Z
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017
Prev: Re: Dump record fields into a text file Andrew Johnson
Next: PCaPAC 2010 - Second call for abstracts Elder Matias
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
