Andrew Johnson wrote on 30/04/10 17:23:
> The first parameter to dbl is the record type (it doesn't actually support
> wild-cards though, "*" or "" are special strings that are explicitly tested
> for and mean all types), so to avoid the issue of missing fields you could
> list each record type separately, giving the fields you're interested in for
> that type:
> dbl bi "RTYP ZRST ONST DTYP DESC" > bi-data.txt
> dbl ai "RTYP PREC EGU DTYP DESC" > ai-data.txt
> dbl calc "RTYP PREC EGU CALC DESC" > calc-data.txt
> etc.
This solution has the risk of "forgetting" records of uncommon record types.
Anyway, I think it would be a nice feature for EPICS 3.15 to create an
empty string if a field does not exist:
dbl * "RTYP PREC EGU DTYP DESC"
test:1,"bi",,,"Soft Channel","desc of test:1"
test:2,"calc","1","unit","","desc of test:2"
test:3,"longout",,"unit","Soft Channel","desc of test:3"
That minor change would easy parsing the dbl output.
Andreas
She often gave herself very good advice (though she very seldom followed
it).
-- Lewis Carroll
- Re: Dump record fields into a text file Andrew Johnson
- Dump record fields into a text file emmanuel_mayssat
- Re: Dump record fields into a text file Luedeke Andreas
<2010>
<2010>
