1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Problem Building SNC/SEQ Module
From: "Pawel Kowalski - BiRa Systems Inc." <[email protected]>
To: "'Andrew Johnson'" <[email protected]>, <[email protected]>
Date: Thu, 29 Apr 2010 13:58:37 -0600
Thanks Andrew, when I commented those lines out it compiled fine. I hope I
don't run in to any issues in the future because of this. Thanks again.
Pawel Kowalski
BiRa Systems Inc.
www.bira.com
Phone:		505-881-8887
Fax:			505-888-0651
Address:		2410 Midtown PL NE
       STE A
       Albuquerque NM 87107 USA
-----Original Message-----
Sent: Thursday, April 29, 2010 1:53 PM
To: [email protected]
Cc: Mark Rivers; Pawel Kowalski - BiRa Systems Inc.
Subject: Re: Problem Building SNC/SEQ Module
On Thursday 29 April 2010 14:41:18 Mark Rivers wrote:
> A little more investigation shows that in snc/Makefile there is the
> following:
> #  Lex library
> SYS_PROD_LIBS_WIN32    += -nil-
> SYS_PROD_LIBS_cygwin32 += -nil-
> SYS_PROD_LIBS_Linux    += fl
> SYS_PROD_LIBS_DEFAULT  += l
> So Linux does require the Lex library.  On Fedora you could install this
> with "yum install flex".
I really don't think that the flex library should be needed since Base
includes its own copy of flex.  I would suggest commenting out *all* of the
lines mark listed above from the Makefile, I just tried it and it worked for
me.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: Problem Building SNC/SEQ Module John William Sinclair
Problem Building SNC/SEQ Module Pawel Kowalski - BiRa Systems Inc.
RE: Problem Building SNC/SEQ Module Mark Rivers
Re: Problem Building SNC/SEQ Module Andrew Johnson
Prev: Re: Problem Building SNC/SEQ Module Andrew Johnson
Next: Re: Problem Building SNC/SEQ Module John William Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
