Carl,
You would think of this in the same manner as you think of someone writing a
script to recursively delete all files in the production directories. In
other words, as soon as
you allow scripts, you need to implement the -ro controls.
Of course, you can always use EPICS access control.
John Sinclair
Carl Schumann wrote:
Our EDM display authors frequently use EDM's shell widget to run
scripts, including scripts that do 'caput's. Such buttons/scripts
appear to be able to do settings even when EDM is started with its -ro
option. While I can understand why this is so from a difficulty of
implementation perspective it does seem to mislead the user. Are my
facts correct? If yes, what does one do or think about it?
Carl Schumann
- EDM's -ro option and running arbitrary scripts w/ in our case caputs Carl Schumann
Re: gateway won't set "busy" PV type properly Andrew Johnson
RE: gateway won't set "busy" PV type properly Mark Rivers
<2010>
RE: EDM's -ro option and running arbitrary scripts w/ in our case caputs Chestnut, Ronald P.
EPICS Installation Vishnu Patel
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
