1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: epicsThreadOnceOsd epicsMutexLock failed
Cc: [email protected]
Date: Fri, 16 Apr 2010 11:06:35 -0500
I believe this was solved with entry 334 in Mantis. R3.14.11 was the first release with the fix. The problem occurred when I connected to PVs from 2 or more IOCs and it happened when I was exiting the program. It only happened rarely, but enough to be a big problem for us.
P.S. How can we search launchpad for Mantis bug numbers?
[email protected] wrote:
Hi Ralph, Xiaoqiang,
This isn't just HP-UX. If I do:
for (( i=0; i<100; i++ )) ; do caget CS-CS-MSTAT-01:MODE; echo $?; done
On RHEL5/R3.14.8.2 this generates the message "epicsThreadOnceOsd
epicsMutexLock failed." (usually, but not always, with exit status 255)
about every 20 caget's.
If I do the same thing on RHEL5/R3.14.11 it doesn't seem to happen (at
least not in 500 tries).
Whatever it is, it seems to have got better with R3.14.11 and so maybe
that's what Xiaoqiang should try. If someone still wants me to generate
a stack trace I can, but maybe we can close it with a message.
Cheers,
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Ralph Lange
Sent: 16 April 2010 16:22
To: Wang Xiaoqiang
Cc: EPICS Tech Talk
Hello Xiaoqiang,
Please note that the EPICS Base bug tracker has been moved to the new EPICS Base location on Lauchpad, this bug is now:
https://bugs.launchpad.net/epics-base/+bug/541249
The old Mantis tracker is still on-line for reference, but it is *not* updated anymore.
The bug is suspended, because Jeff was asking for a stack trace which was never provided.
The bug is about erroneous behavior experienced on the HP-UX operating system.
Support for HP-UX has been dropped with EPICS release 3.14.9, so this bug will most probably never be fixed.
If you experience the error on a different version of EPICS and a different operating system, please check on Launchpad if it has been reported. If not, you are encouraged to file a new bug report.
Thanks a lot,
Ralph
On Fri 16 Apr 2010 10:08:53 Wang Xiaoqiang wrote:
When CA client exit, sometimes it spills out "epicsThreadOnceOsd
epicsMutexLock failed" message. It has been reported since
3.14.7 and
has an entry 207 in Mantis. The status is labeled as
"suspended". Does
it mean it is hopeless to be solved?
http://www.aps.anl.gov/epics/mantis/view_bug_page.php?f_id=207
In normal cases it is harmless since the program is anyway exiting.
However it exits with code 255. If it is run as a
subprocess, this will
cause the caller think exit code other than 0 is wrong and stop
execution. In such case one cannot ignore the exit code, which would
ignore other possible exceptions.
Thanks and nice weekend.
Dr. Xiaoqiang Wang
Paul Scherrer Institut, WBGB/010
5232 Villigen PSI, Switzerland
Re: epicsThreadOnceOsd epicsMutexLock failed Ralph Lange
epicsThreadOnceOsd epicsMutexLock failed Wang Xiaoqiang
RE: epicsThreadOnceOsd epicsMutexLock failed nick.rees
Prev: RE: epicsThreadOnceOsd epicsMutexLock failed nick.rees
Next: Re: epicsThreadOnceOsd epicsMutexLock failed Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
