Thank you Eric,
I thought of doing it as you suggest. I thought it useful to ask before committing myself, since my knowledge of asyn is only sketchy.
Zen
-----Original Message-----
Sent: Thursday, April 15, 2010 12:18 PM
To: Szalata, Zenon M.
Cc: TECHTALK Tech-Talk
Subject: Re: Asyn Question
Could you not just have 32 ports?
drvAsynIPPortConfigure("L01","192.168.1.1:1255 UDP",0,0,0)
drvAsynIPPortConfigure("L02","192.168.1.2:1255 UDP",0,0,0)
drvAsynIPPortConfigure("L03","192.168.1.3:1255 UDP",0,0,0)
On Apr 15, 2010, at 12:07 PM, Szalata, Zenon M. wrote:
> I am designing a soft IOC to run on Linux, which will control and monitor an array of 32 identical network (Ethernet) devices. The network protocol is udp. I will use asyn and most likely streamDevice. What is the most sensible approach to implement this?
> The IOC needs to communicate with all devices present, each with a unique IP address. My uncertainty is how to establish communication with and then address each device as needed. Also how to maintain a list of connections.
> Is there an example of similar implementation?
> I have written a number of soft IOCs to communicate with a single Ethernet device using asyn. Dealing with an array of Ethernet devices seems daunting.
> Any suggestions are welcome,
> Zen
Eric Norum
[email protected]
- Asyn Question Szalata, Zenon M.
- Re: Asyn Question Eric Norum
A Rudimentary EDL to SVG converter Kevin Anderson
How to compile the sysVmeMapShow() function to the MVME5500 BSP? 周永年
<2010>
<2010>
