1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: writing to aao crashes ioc
To: Dirk Zimoch <[email protected]>
Cc: EPICS <[email protected]>
Date: Thu, 15 Apr 2010 14:49:39 -0500
Dirk,  I was seeing something similar (though in 3.14.11),
and "dbpr <recordname>,5" showed "DTYP: <nil>",
until I added the line
device(aao,CONSTANT,devAaoSoft,"Soft Channel")
to the .dbd file.
Tim
Dirk Zimoch wrote:
Hi all,
When an aao is written by an other record, the ioc crashes. The problem seems to independent of the DTYP of the aao. I used an (unofficial) Soft Channel support (attached).
Example db:
record (aao, "aao1")
    field (FTVL, "DOUBLE")
    field (NELM, "10")
    field (OUT,  "aao2")
record (aao, "aao2")
    field (NELM, "10")
record (ao, "ao1")
    field (OUT,  "aao2")
When I write aao1 or ao1 the IOC crashes. (Note that aao2 is not even processed in that case.) If I write directly into aao2 there is no problem.
Any idea?
I am using EPICS R3.14.8.2.
Dirk
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group (www.aps.anl.gov/aod/bcda)
Advanced Photon Source, Argonne National Lab
Re: writing to aao crashes ioc Dirk Zimoch
Prev: Re: Asyn Question Eric Norum
Next: A Rudimentary EDL to SVG converter Kevin Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: writing to aao crashes ioc Dirk Zimoch
Next: Re: writing to aao crashes ioc Dirk Zimoch
