1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: The problem of building IOC
To: "lailongwei" <[email protected]>, "tech-talk" <[email protected]>
Date: Wed, 14 Apr 2010 06:54:48 -0500
It appears that your ddc.dbd file is incorrect.  The problem is probably in how you built that dbd file in your application.
Sent: Tue 4/13/2010 10:19 PM
To: tech-talk
Subject: The problem of building IOC
Hello, I have met problem when I build IOC, following is the result of running the IOC.
#!../../bin/linux-x86/ddc
## You may have to change ddc to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"iocddc")
epicsEnvSet(TOP,"/home/lailw/epics_ioc/board_user_mod")
epicsEnvSet(EPICS_BASE,"/epics/base")
cd /home/lailw/epics_ioc/board_user_mod
dbLoadDatabase("dbd/ddc.dbd")
Error:  record type not found
Parsing ')'
   in file dbd/ddc.dbd line 1
db_parse returned -1
ddc_registerRecordDeviceDriver(pdbbase)
## Load record instances
dbLoadTemplate "db/userHost.substitutions"
filename="../dbLexRoutines.c" line number=912
Record Type does not exist dbFindRecordTypeError.
Parsing ')'
   in file db/dbExample1.db line 1
Parsing ')'
   in file db/dbExample2.db line 1
Parsing ')'
Parsing ')'
dbLoadRecords("db/dbSubExample.db","user=lailwHost")
Parsing ')'
   in file db/dbSubExample.db line 3
## Set this to see messages from mySub
#var mySubDebug 1
cd /home/lailw/epics_ioc/board_user_mod/iocBoot/iocddc
iocInit()
Starting iocInit
## EPICS R3.14.9 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Jan  1 2010
Thread _main_ (0x9bb3098) can't proceed, suspending.
I have tried many times, but this problem always displayed.
Any idea how to fix it?
Thanks.
2010-04-14
lailongwei
The problem of building IOC lailongwei
Prev: The problem of building IOC lailongwei
Next: writing to aao crashes ioc Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
