1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: command line tool to list all field values of a Record ?
To: [email protected]
Date: Mon, 12 Apr 2010 15:22:52 -0500
On Monday 12 April 2010 14:53:09 Ralph Lange wrote:
> Through Channel Access: Not that I know.
John Maclean wrote a Perl script called capr that does this to some extent,
but it's rather old now (2003), relies on the command-line program caget (but
not the one that comes with Base), and as you would expect can only display
those fields of a record that are accessible through CA.  It has to parse a
DBD file to work out what fields each record type has, but it has a default
path and will also read an environment variable so you don't have to specify
the path every time.  I can provide a copy if anyone is interested, but it
will probably need some effort to get it working at another site.
I thought Kay Kasemir had included a tool like this into CSS at one point, but
I might be wrong about that.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: command line tool to list all field values of a Record ? John Dobbins
Re: command line tool to list all field values of a Record ? Ralph Lange
Prev: Re: command line tool to list all field values of a Record ? Ralph Lange
Next: Re: command line tool to list all field values of a Record ? John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
