1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: asyn port question
To: "Eric Norum" <[email protected]>
Cc: [email protected]
Date: Fri, 9 Apr 2010 16:53:21 -0400
I only searched for 'vxi' which is not mentioned.  This is certainly
worth checking.  I don't have it on my desk, so I'll investigate on
Monday.
Michael
> -----Original Message-----
> From: Eric Norum [mailto:[email protected]]
> Sent: Friday, April 09, 2010 4:28 PM
> To: Davidsaver, Michael
> Subject: Re: asyn port question
> The specification sheet for the WaveSurfer scope
> (http://www.lecroy.com/files/pdf/LeCroy_WaveSurfer_XS-a_Specs.pdf)
> claims LXI compliance -- which implies VXI-11 does it not?
> On Apr 9, 2010, at 10:45 AM, Davidsaver, Michael wrote:
> > All,
> > I am looking at a Lecroy wavesurfer scope which is capable of remote
> > control via. a tcp protocol.  The protocol is basically ascii text,
> but
> > is grouped into frames with an 8 byte header.  The header has some
> bits
> > for things like EOI and SRQ and a 32-bit size field.  Basically,
this
> is
> > a simpler (primitive?) way to accomplish the same thing as VXI-11.
> > I haven't done more then read about asyn, but it seems like what I
> would
> > want to do is create an adapter which uses a tcp client port and
> > implements a gpib port.  What I don't know is: how
> complicated/difficult
> > would this be?
> > http://www.lecroy.com/tm/library/manuals/X-
> Stream_Scopes/RemoteControlMa
> > nual/WM-RCM-E_Rev_D.pdf
> > See chapter 3 "Control by LAN"
> > Thanks,
> > Michael Davidsaver
> > NSLSII Controls Group
> > Brookhaven National Lab
> Eric Norum
> [email protected]
asyn port question Davidsaver, Michael
Re: asyn port question Eric Norum
Prev: Re: asyn port question Eric Norum
Next: how to process other records in subroutine record by ca link? Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: asyn port question Davidsaver, Michael
