On Apr 6, 2010, at 9:04 AM, Jovan Loncar wrote:
On 04/03/2010 02:10 PM, Dalesio, Leo wrote:
It is not
totally clear what the goal is......
For collecting scalars into arrays - the Compress record already does this. Bad
name, I know, but it also compresses waveform records. So if the input is an
array, it does successive averages or filters high,low,average. If the input is
a scalar, it is a circular buffer. If all you want to do is take a scalar, and
create a histogram, there is a histogram record.
The subroutine record - as Stephanie points out - also gives you a way to take
one or several arrays, and manipulate them to create a result (or several
results)
If you are trying to marshal many scalars into an array, then there are more
questions before answers. Do you need location? Status for each channel? Time
stamp or time difference from some reference? Does one channel become the
reference? We are working on this type of support to create a suite of tools
right now at NSLS. Hopefully, we have some progress to report at the May
meeting in Aix.
Firstly i would like to thank you all for the responses.
I re-read my first email and i forgot to mention that the scalars i am trying
to put into an array are
not located on the same machine.
For an example:
there are 200 computers (machines) each running their own EPICS server
connected
in the same network. I am able to read the temperatures of each through an
EPICS PV (fo example using caget).
Now, on another computer (in the same network) in the administration room i
would like to monitor all these
temperatures using EDM (or if it is not possible with EDM some other
visualization tool).
But the usual way of displaying this, a box changing colors (red, yellow,
green) is not
enough and also displaying 200 numbers is not user-friendly for the
administrator.
What i would like to achieve is to get all these temperatures and collect them
into
an array and display them onto a X-Y Graph. This way the administrator would be
able to see
what is the temperature and also how much it is drifting from
desired/average/reference. The x-axis are the machines depending on
their own index number, which is fixed. So Machine001 would always be the first
in the array (to display), which means
that the location is very important.
Time stamp and time differences are not crucial, they could be a nice feature
but not important at the moment.
Since all the readings should be independent the timestamp is not important.
One option for the reference could be the average from all, but this one would
be selectable.
The administrator would choose which is the desired temperature of the specific
machine depending
on the position of the machine, the usage of the cooling system etc.
If you only need a plug in EDM, look at the
CALC example. If has channel access on one side and creates a result on the
other side.
Bob
I will take a look if CALC can collect different scalars and create an array.
As i understood the CALC is limited with the number of variables it can
process.
Also if i understand Stephanie correctly one variant would be to have a softIOC
running on the
administrators computer which would collect all the scalars and create the
waveform record.
The EDM would display the updated waveform record. This sounds as a very good
solution
to the problem.
The suggestion made by Matt Newville to use of EpicsCA module in python is also
a very good alternative.
It will definitely be useful for some other work too. Thanks for pointing this
one out for me.
I hope the above description gives a general idea what i want to do. Maybe i
have mislead some of you
when i mentioned histograms, but that was one of the associations that popped
in my mind.
Jovan
