1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EDM text entry: segmentation fault
Cc: [email protected]
Date: Wed, 7 Apr 2010 22:20:27 +0800
Hello Sharon,
On Wed, Apr 7, 2010 at 21:57, Sharon Lackey <[email protected]> wrote:
> Yes I have seen this problem but I believe it was fixed in a later release
> of edm. ÂWhich version are you using?
I normally use 1-11-0zi, but I checked 1-12-28 (the latest available
at http://ics-web.sns.ornl.gov/edm) - same behavior.
What is really puzzling, is that running that edm with remote X
display works fine. Running edm on another machine with the display on
the problem system is also OK. Only running edm locally on a local X
server seems to crash.
Dmitry Teytelman
Re: EDM text entry: segmentation fault Steven M. Hartman
EDM text entry: segmentation fault Sharon Lackey
Prev: EDM text entry: segmentation fault Sharon Lackey
Next: RE: cac_select_io Segmentation fault Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: EDM text entry: segmentation fault Steven M. Hartman
