1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: EDM text entry: segmentation fault
To: [email protected]
Date: Wed, 7 Apr 2010 18:42:41 +0800
Hello all!
I am at my wits end and will take any help I can get. Here is the
problem. EDM crashes with a segfault when executing any panel with a
text entry field (unconnected fields do not cause the fault). I have
tracked the crash to the following call in pvFactory/textupdate.cc:
XtVaSetValues(widget,
                      XmNeditable, True,
                      XmNforeground, (XtArgVal)textColor.getPixel(actWin->ci),
                      NULL);
If I change XmNeditable from True to False, the segfault goes away.
Unfortunately EDM is not useable with that little mod :)
All of this under Red Hat Enterprise Linux 5.4. Has anybody seen
similar behavior?
Thanks in advance!
Dmitry Teytelman
Re: EDM text entry: segmentation fault Andrew Johnson
Prev: cac_select_io Segmentation fault Al Honey
Next: Re: cac_select_io Segmentation fault Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: cac_select_io Segmentation fault Jeff Hill
Next: Re: EDM text entry: segmentation fault Andrew Johnson
