1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: create arrays in EDM
To: Tech Talk <[email protected]>
Date: Fri, 02 Apr 2010 16:56:37 +0200
Hi all,
i am new to EDM and i am trying to create an array from different scalar (integer) PVs.
So that i can display all of them on one X-Y Graph. Only the last reading is neccessary
and the resulting X-Y Graph should look like a "historgram" or sound equalizer (for a visual
understanding of what i am trying to accomplish).
Possibly the result would look something like LOC\\my_array:{EPICS\\A_PV, EPICS\\B_PV, EPICS\\C_PV ...}
The number of scalar PVs can be up to 200 and is constant.
I am not sure if it is possible and if someone has already tried this i would appreciate some help.
If this is not possible only within EDM, then maybe the way to go is to to use some scripts.
I have used the example for edmFilters with python to change the template edl.
But in that example the write to stdout of the script is used by the Embedded Window Widget
to display new/changed screen.
I don't know how to pass the local PVs (LOC) to the python script and back to EDM.
Another option could be to create a new widget, for this task.
I still need to investigate this one, but would not like to reinvent the wheel
in case someone here knows of an existing widget for this kind of operation.
If anyone has another idea or if i am missing something please point me to the
right direction.
Thanks in advance for answers.
Best Regards,
Jovan
RE: create arrays in EDM Allison, Stephanie
Prev: Re: JCA type conversion J. Lewis Muir
Next: RE: create arrays in EDM Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: JCA type conversion Simon Ebner
