1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: asyn R4.12 and streamdevice R2.4
To: "'Mark Rivers'" <[email protected]>, TECHTALK Tech-Talk <[email protected]>
Date: Fri, 19 Mar 2010 08:56:33 -0700
Hi Mark,
I avoided the problem by reverting to asyn R4.9.  I will try putting epicsThreadSleep(5) in my st.cmd file.  I will let you know the result.
Zen
-----Original Message-----
Sent: Friday, March 19, 2010 6:49 AM
To: Szalata, Zenon M.; TECHTALK Tech-Talk
Hi Zen,
Have you resolved this problem?  I would like to try to resolve it
before we release asyn 4-13.  This looks different from the  problem
that Benjamin Franksen just tracked down and posted the patch for.  But
I think he is now successfully using streamDevice R2.4 and asyn R4-12,
which you are having problems with, right?
Does it help to put an epicsThreadSleep(5) after the call to
vxi11Configure and before the call to iocInit?
Sent: Thursday, February 25, 2010 4:18 PM
To: 'Szalata, Zenon M.'; TECHTALK Tech-Talk
I don't have any vxi11 hardware to test.
Hopefully Eric Norum has an idea.
Sent: Thursday, February 25, 2010 3:53 PM
To: Mark Rivers; TECHTALK Tech-Talk
Hi Mark,
Yes, it specific to Vxi11...
Zen
Sent: Thursday, February 25, 2010 1:52 PM
I'm using streamDevice 2-4 with asyn 4-12 on 3.14.10.  I think it is
also working on 3.14.11, but I can't say for sure that I have tested it.
Is this problem specific to vxi11 with streamDevice?  I am only using
streamDevice with TCP and serial.
[mailto:[email protected]] On Behalf Of Szalata, Zenon M.
Sent: Thursday, February 25, 2010 3:41 PM
To: TECHTALK Tech-Talk
Subject: asyn R4.12 and streamdevice R2.4
I am trying to build a simple IOC with EPICS R3.14.11, asyn R4.12, and
streamdevice R2.4.  IOC builds without errors, but fails to run.
I also tried EPICS R3.14.9, asyn R4.12, and streamdevice R2.4 with the
same results.
However, when I build the IOC with EPICS R3.14.9, asyn R4.9, and
streamdevice R2.4 the IOC works well.
It appears that streamdevice R2.4 does not work with asyn R4.12.  I have
another IOC which works well with EPICS R3.14.11 and asyn R4.12.  It
does not use streamdevice.
Here are the errors I get:
epicsEnvSet( EPICS_CA_MAX_ARRAY_BYTES,100000)
epicsEnvSet( ETHER, "134.79.64.25")
cd
/afs/slac.stanford.edu/g/testfac/esb/epics/rhel4/R3.14.9/iocTop/tds/prod
dbLoadDatabase("dbd/tds.dbd",0,0)
tds_registerRecordDeviceDriver(pdbbase)
#TDS3000Reboot $(ETHER)
#epicsThreadSleep(60)
vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
dbLoadRecords( "db/tds.db","P=ESA:TDS:,L=0,A=9,NAME=TDS,PORT=L0")
cd
/iocBoot/sioc-esa-tk01
iocInit()
Starting iocInit
## EPICS R3.14.9-ilc3 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Nov 11 2009
2010/02/25 13:12:51.149 _main_ ESA:TDS:W_CH1_OFF lockRequest:
pasynManager->queueRequest() failed: port L0 not connected
2010/02/25 13:12:51.149 _main_ ESA:TDS:W_CH1_OFF: Can't start init run
2010/02/25 13:12:51.149 _main_ ESA:TDS:W_CH1_OFF: Record initialization
failed
Bad init_rec return value  PV: ESA:TDS:W_CH1_OFF ao: init_record
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH1_POS lockRequest:
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH1_POS: Can't start init run
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH1_POS: Record initialization
failed
Bad init_rec return value  PV: ESA:TDS:W_CH1_POS ao: init_record
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH2_OFF lockRequest:
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH2_OFF: Can't start init run
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH2_OFF: Record initialization
failed
Bad init_rec return value  PV: ESA:TDS:W_CH2_OFF ao: init_record
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH2_POS lockRequest:
Thanks in advance,
Zen
RE: asyn R4.12 and streamdevice R2.4 Szalata, Zenon M.
RE: asyn R4.12 and streamdevice R2.4 Mark Rivers
Prev: support for SRS 725 frequency reference? Davidsaver, Michael
Next: Re: A Qt widget toolkit for EPICS, KWT 1.0 released. Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: asyn R4.12 and streamdevice R2.4 Mark Rivers
Next: Re: aSubRecord Andrew Johnson
