Subject: |
Re: Building StreamDevice 2-4 / SynApps / Win32 |
"J. Lewis Muir" <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Fri, 12 Mar 2010 09:58:56 -0600 |
On 3/12/10 9:47 AM, Mark Rivers wrote:
> Lewis,
> EPICS is advertised to build on Windows with only "make" and "perl"
> (plus a MS compiler) required. Windows does not come with a shell that
> will understand Dirk's script, right? So what shell would you point to?
Hi, Mark.
OK, I see. I didn't know that EPICS was supposed to build w/ only
"make" and "perl". In that case, the for loop command for the target to
build stream.dbd is clearly intended to be run by a Bourne shell and
thus will not work if that shell is not present. So the make target is
broken. It needs to be changed to use perl to do the for loop (or maybe
there's some way to do it w/ GNU make built-in commands).
Lewis
- Re: Building StreamDevice 2-4 / SynApps / Win32 Andrew Johnson
- Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
- RE: Building StreamDevice 2-4 / SynApps / Win32 Mark Rivers
- RE: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
- Re: Building StreamDevice 2-4 / SynApps / Win32 J. Lewis Muir
- Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
<2010>
<2010>
