Lewis,
EPICS is advertised to build on Windows with only "make" and "perl"
(plus a MS compiler) required. Windows does not come with a shell that
will understand Dirk's script, right? So what shell would you point to?
-----Original Message-----
[mailto:[email protected]] On Behalf Of J. Lewis Muir
Sent: Friday, March 12, 2010 9:39 AM
To: EPICS Tech-Talk
Subject: Re: Building StreamDevice 2-4 / SynApps / Win32
On 3/12/10 9:34 AM, John Dobbins wrote:
> J. Lewis Muir wrote:
>> On 3/11/10 10:55 PM, Mark Rivers wrote:
>>> I don't think shell is important on Windows, you can build EPICS in
a
>>> Cygwin bash shell or a Windows cmd shell without having to worry
about
>>> it.
>> Hi, Mark.
>> Note I'm not talking about the shell from which the make command is
>> executed; I'm talking about the shell that make uses to execute
commands
>> for a given target.
>> Lewis
> Lewis, Mark, All,
> It seems to me that an easy thing would be to write a Perl script that
> replicates this code (which is just generating a test file):
> # create stream.dbd from all RECORDS
> $(COMMON_DIR)/$(LIBRARY_DEFAULT).dbd: ../CONFIG_STREAM
> @for r in $(RECORDS); \
> do echo "device($$r,INST_IO,dev$${r}Stream,\"stream\")"; \
> done > $@
> @echo "driver(stream)" >> $@
> @echo "variable(streamDebug, int)" >> $@
> @echo "registrar(streamRegistrar)" >> $@
> endif
> I can do that but am not sure about how to invoke the Perl script and
> pass from $(RECORDS) to the Perl script.
> It would be nice to not have this one part of EPICS dependent on
cygwin
> when the rest it not.
Hi, John.
That would work, but I'm not convinced this one part is dependent on
Cygwin. I still think the problem is just that the target commands are
getting passed to either the wrong shell or a broken shell.
Lewis
- Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
- Re: Building StreamDevice 2-4 / SynApps / Win32 J. Lewis Muir
- Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
- RE: Building StreamDevice 2-4 / SynApps / Win32 Mark Rivers
- RE: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
<2010>
<2010>
