Hi Ron,
As far as I know strcpy(), strlen(), and also sprintf() are all legal
from vxWorks interrupt context. But printf(), fprintf() and such (i.e.
writing to files) is illegal.
Where have you read that ANSI string library calls are nor allowed?
By the way, using floating point, Altivec and such (non-integer register
instructions) in ISR is illegal without precautions.
Dirk
Ron Sluiter wrote:
Eric Norum wrote:
"I have also conditionally added your fix for sprintf() not callable
from the RTEMS interrupt context ..."
I wasn't aware that sprintf() was legal to call from an interrupt
context on vxWorks. Or did I misunderstand the change?
Hello Eric,
No. You did not misunderstand the changes. I was not aware that
sprintf() is
an illegal call from a VxWorks ISR. Now that I look more closely at the
restrictions you pointed out; there is very little allowed from a VxWorks
ISR; e.g., no ANSI string library calls, strcpy(), strlen(), etc.
I guess if I really want an error message sent from an ISR I will have to a
assemble it using stone tools and animal skins.
Thanks for catching this error.
Hello Jens,
I have redone the MAXv ISR error messages using a version of your code.
The latest (unreleased) version is available here;
https://subversion.xor.aps.anl.gov/synApps/motor/trunk/motorApp/OmsSrc/drvMAXv.cc
Ron
On Mar 8, 2010, at 1:18 PM, Ron Sluiter wrote:
Hello Jens,
The common code for the old device support record
initialization; "motor_init_record_com()" was not always
passing positive encoder ratio values. This has been a
bug for a long, long time that is now fixed.
not callable from the RTEMS interrupt context to the
MAXv ISR.
Both of these changes will be available, soon, in the
next release.
Thanks for pointing out these problems,
Ron
[email protected] <mailto:[email protected]> wrote:
Hello Ron,
but the motor record has not issued negative
encoder ratio commands for a long time.
here is an extract of the boot messages with drvMAXvdebug=10, while
autosave writes -5.55123456e-06 to the ERES-field.
send_mess: sent card 0 message:'
AX ER-180140,52359 UU-3.440496
This command (ER-180140,52359) does not work for
current firmware versions.
Are you using a really old
version of the motor record?
No, this is the motorR6-4-4
EpicsRelease 3.14.11
Jens
_______________________________
Jens Eden
Physikalisch-Technische Bundesanstalt
Albert-Einstein-Straße 15
12489 Berlin
Tel +49 30 6392-5086
Fax +49 30 6392-5082
Von:
Ron Sluiter <[email protected] <mailto:[email protected]>>
An:
Kopie:
Datum:
05.03.2010 21:12
Betreff:
Re: 2 MAXv problems
Hello Jens
There has been a recent (R6-4 and above) fix to prevent intermittent
MAXv command
errors from occurring when User Units are turned off, but the motor
record has not
issued negative encoder ratio commands for a long time. Are you
using a really old
Ron
Hi all,
I found, that in recent firmware versions (1.31) of the MAXv cards
the command to set
negative encoder resolutions (e.g. "AX ER-2,3") as used by the MAXv
driver
does not work any more.
Instead a command error is returned and the encoder resolution will
remain
unchanged.
I couldn't find this "new feature" documented anywhere.
Eric Norum
- 2 MAXv problems Jens . Eden
- Re: 2 MAXv problems Ron Sluiter
- Re: 2 MAXv problems Jens . Eden
Re: EDM crashing Hinko Kocevar
<2010>
Re: 2 MAXv problems Ernest L. Williams Jr.
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
