1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: IOC with LOTS of serial ports
To: [email protected]
Date: Mon, 8 Mar 2010 11:45:26 -0600
Hi Bob,
On Monday 08 March 2010 08:28:42 Dalesio, Leo wrote:
> Does anyone have a cheap IOC that can handle 16? 32? 64? - serial ports?
> Moxa has a 16 port version with 4 Ethernet ports for $1300. I'm looking to
> beat this. Thanks,
Does the IOC actually need to be local to the serial ports?  You might find it
cheaper and more flexible to use regular multi-port terminal servers and run
the IOC(s) in a central location.  The Asyn port model makes the difference
between local and remote ports just a few lines in the IOC start-up script,
although I realize that there may be other considerations that prevent you
from using this approach.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: IOC with LOTS of serial ports David Kline
IOC with LOTS of serial ports Dalesio, Leo
Prev: RE: Building EPICS on windows (reprise) John Dobbins
Next: Re: IOC with LOTS of serial ports David Kline
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: IOC with LOTS of serial ports David Dudley
