1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: 2 MAXv problems
To: Ron Sluiter <[email protected]>
Cc: [email protected]
Date: Fri, 5 Mar 2010 23:22:47 +0100
Hello Ron,
> but the motor record has not issued negative
> encoder ratio commands for a long time.
here is an extract of the boot messages with
drvMAXvdebug=10, while autosave writes
-5.55123456e-06 to the ERES-field.
send_mess: sent card 0 message:'
AX  ER-180140,52359 UU-3.440496
This command (ER-180140,52359) does not work for
current firmware versions.
> Are you using a really old
> version of the motor record?
No, this is the
motorR6-4-4
EpicsRelease 3.14.11
Jens
_______________________________
Jens Eden
Physikalisch-Technische Bundesanstalt
Albert-Einstein-Straße 15
12489 Berlin
Tel +49 30 6392-5086
Fax +49 30 6392-5082
Von:
An:
[email protected]
Kopie:
[email protected]
Datum:
05.03.2010 21:12
Betreff:
Re: 2 MAXv problems
Hello Jens
There has been a recent (R6-4 and above) fix to prevent intermittent
MAXv command
errors from occurring when User Units are turned off, but the motor
record has not
issued negative encoder ratio commands for a long time.  Are you using a
really old
Ron
[email protected] wrote:
> Hi all,
> I found, that in recent firmware versions (1.31) of the MAXv cards the
> command to set
> negative encoder resolutions (e.g. "AX ER-2,3") as used by the MAXv
driver
> does not work any more.
> Instead a command error is returned and the encoder resolution will
remain
> unchanged.
> I couldn't find this "new feature" documented anywhere.
Re: 2 MAXv problems Ron Sluiter
2 MAXv problems Jens . Eden
Prev: Re: ChannelArchiver on Solaris? Matthias Clausen
Next: Problem while Launching EDM Hiren Patel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: 2 MAXv problems Ron Sluiter
Next: Re: 2 MAXv problems Ron Sluiter
