Hello Jens
There has been a recent (R6-4 and above) fix to prevent intermittent
MAXv command
errors from occurring when User Units are turned off, but the motor
record has not
issued negative encoder ratio commands for a long time. Are you using a
really old
version of the motor record?
Ron
[email protected] wrote:
Hi all,
I found, that in recent firmware versions (1.31) of the MAXv cards the
command to set
negative encoder resolutions (e.g. "AX ER-2,3") as used by the MAXv driver
does not work any more.
Instead a command error is returned and the encoder resolution will remain
unchanged.
I couldn't find this "new feature" documented anywhere.
- Re: 2 MAXv problems Jens . Eden
- 2 MAXv problems Jens . Eden
Re: ChannelArchiver on Solaris? Ralph Lange
Re: ChannelArchiver on Solaris? Matthias Clausen
<2010>
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
