Hi all,
I found, that in recent firmware versions (1.31) of the MAXv cards the
command to set
negative encoder resolutions (e.g. "AX ER-2,3") as used by the MAXv driver
does not work any more.
Instead a command error is returned and the encoder resolution will remain
unchanged.
I couldn't find this "new feature" documented anywhere.
For the MAXp-card I verified, that this behaviour was introduced between
firmware versions 1.29 and 1.31.
The workaround is to not use negative encoder resolution, instead reverse
the encoder direction
with the new EDI command in the init-string.
If using RTEMS the ioc crashes, when calling sprintf in interrupt context
(motorIsr() in drvMAXv.cc) .
I assume, calling sprintf() in interrupt context is not allowed in RTEMS?
Jens
- Re: 2 MAXv problems Ron Sluiter
- Re: 2 MAXv problems Joachim Rahn
Re: compile error with medm 3.1.3 on fedora 10 Robert Soliday
Re: MBBO update Hinko Kocevar
<2010>
Re: ChannelArchiver on Solaris? Matthias Clausen
<2010>
