1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: compile error with medm 3.1.3 on fedora 10
To: Geoff Savage <[email protected]>, [email protected]
Date: Fri, 5 Mar 2010 12:04:22 +0530 (IST)
Thanks Geoff,
That thing worked...
But stuck again at another error..
make[1]: *** No rule to make target `/usr/lib/libXm.a', needed by `probe'.  Stop.
make[1]: Leaving directory `/usr/local/epics/extensions/src/probe1_1_5_1/O.linux-x86_64'
make: *** [install.linux-x86_64] Error 2
Is this Fedora 12 or something I didn't do correct.
Now i am trying copying that file directly to the library from internet.. Hope it will work.
     Hitesh Dhola
     Power Supply Group
     ITER-INDIA, Institute for Plasma Research
     A-29, GIDC, Sector-25
     Gandhinagar 382025, INDIA
     Ph: +917923269614
     WWW.ITER-India.org
----- Original Message -----
To: "Hitesh Dhola" <[email protected]>
Sent: Thursday, March 4, 2010 8:41:48 PM GMT +05:30 Chennai, Kolkata, Mumbai, New Delhi
Hi Hitesh,
Your file names need a capital X, Xm.h and XmP.h.
 > yum provides XmP.h
openmotif-devel.i386                     2.2.3-10.2.el4         sl-base
Matched from:
/usr/X11R6/include/Xm/XmP.h
 > yum provides Xm.h
Matched from:
/usr/X11R6/include/Xm/Xm.h
As Michael Davidsaver wrote yesterday the headers you need are in
openmotif-devel.  I am not a Linux expert so I don't know where the
header files on your system are located.  Our linux computers use
RHEL4 built into Scientific Linux Fermi 4.
In your build line you look for X11 files in the -I/usr/include/X11
directory.  But the files you need are not in this directory so you
need to modify your build configuration.  In <top>/configure/os/
CONFIG_SITE.linux-x86_64.linux-x86_64 adjust the MOTIF_LIB and
MOTIF_INC to match your configuration.  When you make a change in the
configure directory you need to gmake clean uninstall and then gmake.
Geoff
On Mar 3, 2010, at 10:53 PM, Hitesh Dhola wrote:
> I have installed libxp-devel and openmotif-devel libraries, then
> also xm.h and xmP.h is not available
>     Hitesh Dhola
>     Power Supply Group
>     Ph: +917923269614
>     WWW.ITER-India.org
> From: "Geoff Savage" <[email protected]>
> To: "Hitesh" <[email protected]>
> Sent: Wednesday, March 3, 2010 8:24:41 PM GMT +05:30 Chennai,
> On Linux, to get  header files you need to install the development
> version of packages.
> Geoff
> On Mar 3, 2010, at 12:16 AM, Hitesh wrote:
>> I am getting same problem compiling MEDM .. at Caption.c .. and xm/
>> xmP.h ...
>> but could not solve using this solution given by tech talk I have
>> included
>> at bottom of this mail.
>> I have install all openmotif library and libxp libraries but.. xm/
>> xmP.h is
>> not in include folder or anywhere
>> And I am getting same error
>> If anyone can help. I am using Fedora 12 64 bit, EPICS base-3-14-11,
>> extension medm3_1_4
>> My errors...
>> Make -C ./printUtils install
>> make[1]: Entering directory
>> `/usr/local/epics/extensions/src/medm/printUtils'
>> make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. T_A=linux-
>> x86_64
>> install
>> make[2]: Entering directory
>> `/usr/local/epics/extensions/src/medm/printUtils/O.linux-x86_64'
>> make[2]: Nothing to be done for `install'.
>> make[2]: Leaving directory
>> make[1]: Leaving directory `/usr/local/epics/extensions/src/medm/
>> printUtils'
>> make -C ./xc install
>> make[1]: Entering directory `/usr/local/epics/extensions/src/medm/xc'
>> x86_64
>> install
>> `/usr/local/epics/extensions/src/medm/xc/O.linux-x86_64'
>> Can't delete Caption.depends: Permission denied
>> make[2]: [Caption.o] Error 13 (ignored)
>> /usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
>> -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -
>> Dlinux
>> -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -I. -I../O.Common -
>> I. -I..
>> -I../../../../include/os/Linux -I../../../../include
>> -I../../../../../base-3-14-11/include/os/Linux
>> -I../../../../../base-3-14-11/include  -I../../../../include
>> -I/usr/include -I/usr/include/X11    ../Caption.c
>> ../Caption.c:30:20: error: Xm/XmP.h: No such file or directory
>> ../Caption.c:33:22: error: Xm/Label.h: No such file or directory
>> In file included from ../CaptionP.h:36,
>>                from ../Caption.c:34:
>> ../Caption.h:36:19: error: Xm/Xm.h: No such file or directory
>> In file included from ../Caption.h:37,
>> /usr/include/X11/Core.h:58: error: expected '=', ',', ';', 'asm' or
>> '__attribute__' before 'typedef'
>> /usr/include/X11/Core.h:60: error: expected '=', ',', ';', 'asm' or
>> '__attribute__' before 'WidgetClass'
>> /usr/include/X11/Core.h:63: error: expected '=', ',', ';', 'asm' or
>> ../Caption.h:70: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> before 'extern'
>> In file included from ../Caption.c:34:
>> ../CaptionP.h:38:25: error: Xm/ManagerP.h: No such file or directory
>> ../CaptionP.h:45: error: expected specifier-qualifier-list before
>> 'XtPointer'
>> ../CaptionP.h:52: error: expected specifier-qualifier-list before
>> 'CoreClassPart'
>> ../CaptionP.h:66: error: expected specifier-qualifier-list before
>> 'XmFontList'
>> ../CaptionP.h:83: error: expected specifier-qualifier-list before
>> 'CorePart'
>> ../Caption.c:38: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> before 'resources'
>> ../Caption.c:77: error: expected ')' before 'greq'
>> ../Caption.c:79: error: expected ')' before 'w'
>> ../Caption.c:80: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> before 'SetValues'
>> ../Caption.c:82: error: expected ')' before 'gold'
>> ../Caption.c:84: error: expected ')' before 'gcw'
>> ../Caption.c:85: error: expected ')' before 'w'
>> ../Caption.c:86: error: expected ')' before 'gcw'
>> ../Caption.c:87: error: expected ')' before 'gcw'
>> ../Caption.c:88: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> before 'GeometryManager'
>> ../Caption.c:90: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> before 'QueryGeometry'
>> ../Caption.c:97: error: expected declaration specifiers or '...'
>> before
>> 'Dimension'
>> ../Caption.c:98: error: expected declaration specifiers or '...'
>> before
>> 'Dimension'
>> before
>> 'Dimension'
>> before
>> 'Dimension'
>> ../Caption.c:99: error: expected declaration specifiers or '...'
>> before
>> 'Dimension'
>> ../Caption.c:100: error: expected declaration specifiers or '...'
>> before
>> 'Dimension'
>> ../Caption.c:101: error: expected declaration specifiers or '...'
>> before
>> 'Dimension'
>> before
>> 'Dimension'
>> before
>> 'Dimension'
>> ../Caption.c:102: error: expected declaration specifiers or '...'
>> before
>> 'Dimension'
>> ../Caption.c:103: error: expected declaration specifiers or '...'
>> before
>> 'Boolean'
>> ../Caption.c:104: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> before 'CompareStrings'
>> ../Caption.c:109: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> before 'CvtStringToLabelAlignment'
>> ../Caption.c:111: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> before 'CvtStringToLabelPosition'
>> ../Caption.c:115: error: extra brace group at end of initializer
>> ../Caption.c:115: error: (near initialization for
>> 'xbaeCaptionClassRec')
>> ../Caption.c:117: error: 'WidgetClass' undeclared here (not in a
>> function)
>> ../Caption.c:117: error: 'xmManagerClassRec' undeclared here (not
>> in a
>> function)
>> ../Caption.c:121: error: 'NULL' undeclared here (not in a function)
>> ../Caption.c:122: error: 'False' undeclared here (not in a function)
>> ../Caption.c:123: error: 'Initialize' undeclared here (not in a
>> function)
>> ../Caption.c:125: error: 'XtInheritRealize' undeclared here (not in a
>> function)
>> ../Caption.c:128: error: 'resources' undeclared here (not in a
>> function)
>> ../Caption.c:129: warning: implicit declaration of function
>> 'XtNumber'
>> ../Caption.c:130: error: 'NULLQUARK' undeclared here (not in a
>> function)
>> ../Caption.c:131: error: 'True' undeclared here (not in a function)
>> ../Caption.c:132: error: 'XtExposeCompressMaximal' undeclared here
>> (not in a
>> function)
>> ../Caption.c:136: error: 'Resize' undeclared here (not in a function)
>> ../Caption.c:137: error: 'Redisplay' undeclared here (not in a
>> function)
>> ../Caption.c:138: error: 'SetValues' undeclared here (not in a
>> function)
>> ../Caption.c:140: error: 'SetValuesAlmost' undeclared here (not in a
>> function)
>> ../Caption.c:141: error: 'GetValuesHook' undeclared here (not in a
>> function)
>> ../Caption.c:143: error: 'XtVersion' undeclared here (not in a
>> function)
>> ../Caption.c:145: error: 'XtInheritTranslations' undeclared here
>> (not in a
>> function)
>> ../Caption.c:146: error: 'QueryGeometry' undeclared here (not in a
>> function)
>> ../Caption.c:149: warning: excess elements in struct initializer
>> ../Caption.c:149: warning: (near initialization for
>> ../Caption.c:150: error: extra brace group at end of initializer
>> ../Caption.c:150: error: (near initialization for
>> ../Caption.c:152: error: 'GeometryManager' undeclared here (not in a
>> function)
>> ../Caption.c:153: error: 'ChangeManaged' undeclared here (not in a
>> function)
>> ../Caption.c:154: error: 'InsertChild' undeclared here (not in a
>> function)
>> ../Caption.c:155: error: 'XtInheritDeleteChild' undeclared here (not
>> in a
>> function)
>> ../Caption.c:157: warning: excess elements in struct initializer
>> ../Caption.c:157: warning: (near initialization for
>> ../Caption.c:158: error: extra brace group at end of initializer
>> ../Caption.c:158: error: (near initialization for
>> ../Caption.c:167: warning: excess elements in struct initializer
>> ../Caption.c:167: warning: (near initialization for
>> ../Caption.c:168: error: extra brace group at end of initializer
>> ../Caption.c:168: error: (near initialization for
>> ../Caption.c:175: error: 'XmInheritParentProcess' undeclared here
>> (not in a
>> function)
>> ../Caption.c:177: warning: excess elements in struct initializer
>> ../Caption.c:177: warning: (near initialization for
>> ../Caption.c:178: error: extra brace group at end of initializer
>> ../Caption.c:178: error: (near initialization for
>> ../Caption.c:181: warning: excess elements in struct initializer
>> ../Caption.c:181: warning: (near initialization for
>> ../Caption.c:184: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> before 'xbaeCaptionWidgetClass'
>> ../Caption.c: In function 'ClassInitialize':
>> ../Caption.c:190: warning: implicit declaration of function
>> 'XtSetTypeConverter'
>> ../Caption.c:190: error: 'XmRString' undeclared (first use in this
>> function)
>> ../Caption.c:190: error: (Each undeclared identifier is reported
>> only once
>> ../Caption.c:190: error: for each function it appears in.)
>> ../Caption.c:191: error: 'CvtStringToLabelAlignment' undeclared
>> (first use
>> in this function)
>> ../Caption.c:192: error: 'XtCacheAll' undeclared (first use in this
>> function)
>> ../Caption.c:195: error: 'CvtStringToLabelPosition' undeclared
>> (first use in
>> this function)
>> ../Caption.c: At top level:
>> ../Caption.c:200: error: expected ')' before 'greq'
>> ../Caption.c:274: error: expected ')' before 'w'
>> ../Caption.c:291: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> before 'SetValues'
>> ../Caption.c:431: error: expected ')' before 'w'
>> ../Caption.c:437: error: expected ')' before 'gold'
>> ../Caption.c:463: error: expected ')' before 'gcw'
>> ../Caption.c:486: error: expected declaration specifiers or '...'
>> before
>> 'Boolean'
>> ../Caption.c: In function 'Layout':
>> ../Caption.c:488: error: 'Position' undeclared (first use in this
>> function)
>> ../Caption.c:488: error: expected ';' before 'label_x'
>> ../Caption.c:489: error: expected ';' before 'user_x'
>> ../Caption.c:490: error: 'Dimension' undeclared (first use in this
>> function)
>> ../Caption.c:490: error: expected ';' before 'user_width'
>> ../Caption.c:495: error: 'CompositeWidget' undeclared (first use in
>> this
>> function)
>> ../Caption.c:495: error: expected ')' before 'cw'
>> ../Caption.c:495: warning: implicit declaration of function
>> 'XtIsManaged'
>> ../Caption.c:496: warning: implicit declaration of function
>> 'XtMoveWidget'
>> ../Caption.c:496: error: expected ')' before 'cw'
>> ../Caption.c:503: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:507: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:509: error: 'label_y' undeclared (first use in this
>> function)
>> ../Caption.c:512: error: 'struct _XbaeCaptionRec' has no member
>> named 'core'
>> ../Caption.c:513: error: expected ')' before 'cw'
>> ../Caption.c:516: error: 'struct _XbaeCaptionRec' has no member
>> named 'core'
>> ../Caption.c:516: error: expected ')' before 'cw'
>> ../Caption.c:519: error: 'user_y' undeclared (first use in this
>> function)
>> ../Caption.c:524: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:526: error: 'label_x' undeclared (first use in this
>> function)
>> ../Caption.c:529: error: 'struct _XbaeCaptionRec' has no member
>> named 'core'
>> ../Caption.c:530: error: expected ')' before 'cw'
>> ../Caption.c:533: error: 'struct _XbaeCaptionRec' has no member
>> named 'core'
>> ../Caption.c:533: error: expected ')' before 'cw'
>> ../Caption.c:536: error: 'user_x' undeclared (first use in this
>> function)
>> ../Caption.c:544: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:547: error: expected ')' before 'cw'
>> ../Caption.c:547: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:549: error: expected ')' before 'cw'
>> ../Caption.c:550: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:553: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:559: error: expected ')' before 'cw'
>> ../Caption.c:559: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:560: error: 'struct _XbaeCaptionRec' has no member
>> named 'core'
>> ../Caption.c:560: error: expected ')' before 'cw'
>> ../Caption.c:562: error: 'struct _XbaeCaptionRec' has no member
>> named 'core'
>> ../Caption.c:562: error: expected ')' before 'cw'
>> ../Caption.c:563: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:568: error: expected ')' before 'cw'
>> ../Caption.c:568: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:570: error: expected ')' before 'cw'
>> ../Caption.c:571: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:574: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:581: error: 'struct _XbaeCaptionRec' has no member
>> named 'core'
>> ../Caption.c:581: error: expected ')' before 'cw'
>> ../Caption.c:583: error: expected ')' before 'cw'
>> ../Caption.c:583: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:584: error: 'struct _XbaeCaptionRec' has no member
>> named 'core'
>> ../Caption.c:584: error: expected ')' before 'cw'
>> ../Caption.c:586: error: 'struct _XbaeCaptionRec' has no member
>> named 'core'
>> ../Caption.c:587: error: expected ')' before 'cw'
>> ../Caption.c:587: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:595: error: expected ')' before 'cw'
>> ../Caption.c:598: error: 'configure' undeclared (first use in this
>> function)
>> ../Caption.c:602: error: 'struct _XbaeCaptionRec' has no member
>> named 'core'
>> named 'core'
>> ../Caption.c:603: error: 'user_width' undeclared (first use in this
>> function)
>> ../Caption.c:603: error: 'user_height' undeclared (first use in this
>> function)
>> ../Caption.c:604: error: expected ')' before 'cw'
>> ../Caption.c:604: error: too many arguments to function
>> 'ComputeUserChildSize'
>> ../Caption.c:612: warning: implicit declaration of function
>> '_XmConfigureObject'
>> ../Caption.c:612: error: 'Widget' undeclared (first use in this
>> function)
>> ../Caption.c:612: error: expected ')' before 'cw'
>> ../Caption.c:615: error: expected ')' before 'cw'
>> ../Caption.c:620: error: expected ')' before 'gcw'
>> ../Caption.c:632: error: expected declaration specifiers or '...'
>> before
>> 'Dimension'
>> before
>> 'Dimension'
>> ../Caption.c:633: error: expected declaration specifiers or '...'
>> before
>> 'Dimension'
>> before
>> 'Dimension'
>> ../Caption.c:634: error: expected declaration specifiers or '...'
>> before
>> 'Dimension'
>> ../Caption.c: In function 'ComputeUserChildSize':
>> ../Caption.c:636: error: 'cwWidth' undeclared (first use in this
>> function)
>> ../Caption.c:636: error: 'childBorderWidth' undeclared (first use in
>> this
>> function)
>> ../Caption.c:637: error: 'cwHeight' undeclared (first use in this
>> function)
>> ../Caption.c:649: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:652: error: 'CompositeWidget' undeclared (first use in
>> this
>> function)
>> ../Caption.c:652: error: expected ')' before 'cw'
>> ../Caption.c:652: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:653: error: expected ')' before 'cw'
>> ../Caption.c:654: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:658: error: expected ')' before 'cw'
>> ../Caption.c:658: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:659: error: expected ')' before 'cw'
>> ../Caption.c:660: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:665: error: 'childWidth' undeclared (first use in this
>> function)
>> ../Caption.c:670: error: 'childHeight' undeclared (first use in this
>> function)
>> ../Caption.c:681: error: expected declaration specifiers or '...'
>> before
>> 'Dimension'
>> before
>> 'Dimension'
>> ../Caption.c:682: error: expected declaration specifiers or '...'
>> before
>> 'Dimension'
>> before
>> 'Dimension'
>> before
>> 'Dimension'
>> ../Caption.c: In function 'ComputeSize':
>> ../Caption.c:684: error: 'childWidth' undeclared (first use in this
>> function)
>> ../Caption.c:684: error: 'childBorderWidth' undeclared (first use in
>> this
>> function)
>> ../Caption.c:685: error: 'childHeight' undeclared (first use in this
>> function)
>> ../Caption.c:691: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:694: error: 'CompositeWidget' undeclared (first use in
>> this
>> function)
>> ../Caption.c:694: error: expected ')' before 'cw'
>> ../Caption.c:694: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:695: error: 'cwWidth' undeclared (first use in this
>> function)
>> ../Caption.c:695: error: expected ')' before 'cw'
>> ../Caption.c:696: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:700: error: 'cwHeight' undeclared (first use in this
>> function)
>> ../Caption.c:700: error: expected ')' before 'cw'
>> ../Caption.c:702: error: expected ')' before 'cw'
>> ../Caption.c:707: error: expected ')' before 'cw'
>> ../Caption.c:707: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:708: error: expected ')' before 'cw'
>> ../Caption.c:709: error: 'struct _XbaeCaptionRec' has no member named
>> 'caption'
>> ../Caption.c:713: error: expected ')' before 'cw'
>> ../Caption.c:715: error: expected ')' before 'cw'
>> ../Caption.c:721: error: expected ')' before 'gcw'
>> ../Caption.c:760: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> ../Caption.c:904: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> ../Caption.c:1041: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> ../Caption.c:1066: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> ../Caption.c:1112: error: expected '=', ',', ';', 'asm' or
>> '__attribute__'
>> make[2]: *** [Caption.o] Error 1
>> make[1]: *** [install.linux-x86_64] Error 2
>> make[1]: Leaving directory `/usr/local/epics/extensions/src/medm/xc'
>> make: *** [xc.install] Error 2
>>  Hitesh Dhola
>>   Power Supply Group
>>   Ph: 079-23269614
>>   www.iter-india.org
>> I have referred this Tech talk,
>> To:
>> [email protected]
>> Subject:
>> From:
>> Kazimierz Gofron <[email protected]>
>> Date:
>> Sat, 09 May 2009 22:18:43 -0500
>> Cc:
>> [email protected]
>> If you see the following error when trying to compile medm 3.1.3 on
>> fedora
>> 10:
>> -D_XOPEN_SOURCE=500
>>          -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -
>> ansi   -O3
>> -W
>> all      -m32     -g -fPIC -I. -I../O.Common -I. -I..
>> inux -I../../../../include -I../../../../../base/include/os/Linux
>> -I../../../../
>> ../base/include  -I../../../../include      -I/usr/include
>> -I/usr/include/X11
>> ../Caption.c
>> In file included from /usr/include/Xm/XmP.h:58,
>>                from ../Caption.c:30:
>> /usr/include/Xm/Xm.h:76:34: error: X11/extensions/Print.h: No such
>> file or
>> direc
>> tory
>> /usr/include/Xm/Xm.h:858: error: expected specifier-qualifier-list
>> before
>> 'XPCon
>> text'
>> gmake[2]: *** [Caption.o] Error 1
>> Just install the missing libraries:
>> yum install libXp libXp-devel <enter>
>> The libXp-devel rpm does not seem to be in openmotif dependencies
>> list.
>> openmotif-2.3.2-1.i386
>> openmotif-devel-2.3.2-1.i386
>> Kazimierz,
Re: compile error with medm 3.1.3 on fedora 10 Robert Soliday
Prev: Re: compile error with medm 3.1.3 on fedora 10 Geoff Savage
Next: Reading 32 bit floats David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: compile error with medm 3.1.3 on fedora 10 Hitesh
Next: Re: compile error with medm 3.1.3 on fedora 10 Robert Soliday
