Subject: |
asyn R4.12 and streamdevice R2.4 |
"Szalata, Zenon M." <[email protected]> |
To: |
"TECHTALK Tech-Talk" <[email protected]> |
Date: |
Thu, 25 Feb 2010 13:40:39 -0800 |
I am trying to build a simple IOC with EPICS R3.14.11, asyn R4.12, and
streamdevice R2.4. IOC builds without errors, but fails to run.
I also tried EPICS R3.14.9, asyn R4.12, and streamdevice R2.4 with the
same results.
However, when I build the IOC with EPICS R3.14.9, asyn R4.9, and
streamdevice R2.4 the IOC works well.
It appears that streamdevice R2.4 does not work with asyn R4.12. I have
another IOC which works well with EPICS R3.14.11 and asyn R4.12. It
does not use streamdevice.
Here are the errors I get:
epicsEnvSet( EPICS_CA_MAX_ARRAY_BYTES,100000)
epicsEnvSet( ETHER, "134.79.64.25")
cd
/afs/slac.stanford.edu/g/testfac/esb/epics/rhel4/R3.14.9/iocTop/tds/prod
dbLoadDatabase("dbd/tds.dbd",0,0)
tds_registerRecordDeviceDriver(pdbbase)
#TDS3000Reboot $(ETHER)
#epicsThreadSleep(60)
vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
dbLoadRecords( "db/tds.db","P=ESA:TDS:,L=0,A=9,NAME=TDS,PORT=L0")
cd
/iocBoot/sioc-esa-tk01
iocInit()
Starting iocInit
## EPICS R3.14.9-ilc3 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Nov 11 2009
2010/02/25 13:12:51.149 _main_ ESA:TDS:W_CH1_OFF lockRequest:
pasynManager->queueRequest() failed: port L0 not connected
2010/02/25 13:12:51.149 _main_ ESA:TDS:W_CH1_OFF: Can't start init run
2010/02/25 13:12:51.149 _main_ ESA:TDS:W_CH1_OFF: Record initialization
failed
Bad init_rec return value PV: ESA:TDS:W_CH1_OFF ao: init_record
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH1_POS lockRequest:
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH1_POS: Can't start init run
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH1_POS: Record initialization
failed
Bad init_rec return value PV: ESA:TDS:W_CH1_POS ao: init_record
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH2_OFF lockRequest:
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH2_OFF: Can't start init run
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH2_OFF: Record initialization
failed
Bad init_rec return value PV: ESA:TDS:W_CH2_OFF ao: init_record
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH2_POS lockRequest:
Thanks in advance,
Zen
- RE: asyn R4.12 and streamdevice R2.4 Mark Rivers
Re: Fwd: Sequencer bug? Benjamin Franksen
<2010>
RE: EPICS Codeathon before the ITER meeting nick.rees
<2010>
