1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Fwd: Sequencer bug?
To: [email protected]
Date: Thu, 25 Feb 2010 22:05:47 +0100
On Donnerstag, 25. Februar 2010, Mark Rivers wrote:
> I think every one of my state programs does pvPut and monitors on the
> same PV.  Generally they do the following:
> - Put a monitor and an event flag on a PV which is a bo or busy record
> int     build;       assign build        to "{P}{R}Build.VAL";
> evflag buildMon;       sync build        buildMon;
> - Have a when clause like the following:
>   when(efTestAndClear(buildMon) && (build==1)) {
>         } state build
Using an event flag here looks redundant to me. There should be no
difference to the simpler
  when(build==1) {
  } state build
>  - Set boVal back 0 to, do a pvPut
>    /* Clear build command, post.  This is a "busy" record, don't want
>     * to do this until build is complete. */
>      build=0;
>      pvPut(build);
> The check for build=1 is needed because the event will also fire as a
> result of the pvPut of the boVal back to 0.  That behaviour actually
> changed in some version of the sequencer several years ago (previously I
> could avoid the event flag being set as a result of the pvPut in the SNL
> program).
> I don't see anything wrong with the above logic,
Neither did I until I had these strange failures (they started to appear
about two months ago), tried some half-hearted fixes that didn't help and
then finally reduced the program to the simple test case, massaged and
instrumented it until I could reliably reproduce the error, and after that
me and my colleague thought very long and hard about it.
This doesn't mean your logic is wrong. What you do may be perfectly safe,
for all I know.
> and I hope I don't a
> bunch a warnings in a new version of the sequencer.
Yes, maybe this is a bit too conservative. Any other ideas?
> Is the problem that
> was recently discussed limited to the case of multiple state sets
> monitoring the same PV?
Well, the exact instance of the problem appears as I stated it only if one
state variable is used to communicate both start _and_ completion between
two state sets working together like co-routines. However, there may lurk
similar problems in other programs. The problem, the reason why I posted
the result of our analysis, is that these things are so very hard to see it
in the code. I was almost certain that my logic was flawless and nothing
bad should happen. I was wrong.
BTW, there are very simple measures to avoid the (my) problem. One can use
two state variables, both assigned to the same PV, each one used by only
one state set. One can also use two event flags and no PV, where one event
flag starts the worker, and the other signals completion.
Cheers
Ben
Re: Sequencer bug? Benjamin Franksen
Re: Fwd: Sequencer bug? Andrew Johnson
RE: Fwd: Sequencer bug? Mark Rivers
Prev: Re: Fwd: Sequencer bug? Tim Mooney
Next: asyn R4.12 and streamdevice R2.4 Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Fwd: Sequencer bug? Mark Rivers
Next: Re: Fwd: Sequencer bug? Tim Mooney
