I think every one of my state programs does pvPut and monitors on the
same PV. Generally they do the following:
- Put a monitor and an event flag on a PV which is a bo or busy record
int build; assign build to "{P}{R}Build.VAL";
evflag buildMon; sync build buildMon;
- Have a when clause like the following:
when(efTestAndClear(buildMon) && (build==1)) {
} state build
- Set boVal back 0 to, do a pvPut
/* Clear build command, post. This is a "busy" record, don't want
* to do this until build is complete. */
build=0;
pvPut(build);
The check for build=1 is needed because the event will also fire as a
result of the pvPut of the boVal back to 0. That behaviour actually
changed in some version of the sequencer several years ago (previously I
could avoid the event flag being set as a result of the pvPut in the SNL
program).
I don't see anything wrong with the above logic, and I hope I don't a
bunch a warnings in a new version of the sequencer. Is the problem that
was recently discussed limited to the case of multiple state sets
monitoring the same PV?
-----Original Message-----
[mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Thursday, February 25, 2010 12:02 PM
To: [email protected]
Subject: Re: Fwd: Sequencer bug?
On Thursday 25 February 2010 07:43:51 Benjamin Franksen wrote:
> It remains to draw practical conclusions for how to avoid such race
> conditions in SNL code. Should we generally be wary of pvPut and
monitor to
> the same state variable?
That is certainly my recommendation, since doing so avoids having to
think
through the possible consequences for the state program. Thanks for
posting
your detailed analysis, I think it shows that the issue is a very subtle
one.
When I've suggested not doing that in the past some people have said
that they
use the technique without problems, but I suspect that they could still
suffer
from it under some circumstances, they just haven't seen it /yet/ (or
maybe
their application doesn't fail spectacularly when it happens).
> Could the compiler warn us about that? Or is this too restrictive?
If someone wants to develop the code to add that as a warning I would be
in
favour of merging it. I suspect that it wouldn't be too hard to do,
you'd do
the check whenever you process a pvPut() call (but I'm not a compiler
writer
so I could be wrong about the difficulty). As long as it's a warning I
don't
think it would be too restrictive (C and C++ compilers have a long
history of
adding warnings as the developers discover more common anti-patterns).
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- RE: Fwd: Sequencer bug? Mark Rivers
- Re: Fwd: Sequencer bug? Benjamin Franksen
- Re: Sequencer bug? Benjamin Franksen
- Re: Fwd: Sequencer bug? Andrew Johnson
<2010>
<2010>
