1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Fwd: Sequencer bug?
To: [email protected]
Date: Thu, 25 Feb 2010 12:02:22 -0600
On Thursday 25 February 2010 07:43:51 Benjamin Franksen wrote:
> It remains to draw practical conclusions for how to avoid such race
> conditions in SNL code. Should we generally be wary of pvPut and monitor to
> the same state variable?
That is certainly my recommendation, since doing so avoids having to think
through the possible consequences for the state program.  Thanks for posting
your detailed analysis, I think it shows that the issue is a very subtle one.
When I've suggested not doing that in the past some people have said that they
use the technique without problems, but I suspect that they could still suffer
from it under some circumstances, they just haven't seen it /yet/ (or maybe
their application doesn't fail spectacularly when it happens).
> Could the compiler warn us about that? Or is this too restrictive?
If someone wants to develop the code to add that as a warning I would be in
favour of merging it.  I suspect that it wouldn't be too hard to do, you'd do
the check whenever you process a pvPut() call (but I'm not a compiler writer
so I could be wrong about the difficulty).  As long as it's a warning I don't
think it would be too restrictive (C and C++ compilers have a long history of
adding warnings as the developers discover more common anti-patterns).
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
RE: Fwd: Sequencer bug? Mark Rivers
Re: Sequencer bug? Benjamin Franksen
Re: Fwd: Sequencer bug? Benjamin Franksen
Prev: EPICS Spring 2010 Collaboration meeting Di Maio Franck
Next: RE: Fwd: Sequencer bug? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Fwd: Sequencer bug? Benjamin Franksen
