1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Epics Base 3.14.9 compilation errors for Fedora 11 64 bit version
To: [email protected]
Date: Tue, 23 Feb 2010 17:50:02 -0500
Hi Andrew,
     The details you gave helped me in compiling Epics Base 3.14.9 on 64 bit Fedora 11. Yes, we will be using it for Channel Access Clients only.
     The shared libraries were installed, however the softlink was pointing to non-existing library. I changed it to point to the correct library and compiled the code. Thank you very much.
Best Regards,
Ramu
Andrew Johnson wrote:
Hi Ramu,
On Monday 22 February 2010 18:59:03 Ramu Denduluri wrote:
I was trying to compile Epics base 3.14.9 on 64 bit Fedora 11 operating
system and got compilation errors as follows:
We don't have access to any Fedora 11 systems here so what I say below might
not be quite right, but we suspect that you're missing an RPM and that the
error you're getting isn't an EPICS issue as such.
However I would advise you that Base R3.14.9 built for a 64-bit machine should
*only* be used for Channel Access clients (and be aware that some of the
standard clients like StripTool and ALH may not work on 64-bit at all yet);
the IOC code was not properly patched to work on 64-bit until R3.14.10.
/usr/bin/ld:
/usr/lib/gcc/x86_64-redhat-linux/4.4.1/libstdc++.a(stdexcept.o):
relocation R_X86_64_32S against `vtable for std::runtime_error' can not
be used when making a shared object; recompile with -fPIC
/usr/lib/gcc/x86_64-redhat-linux/4.4.1/libstdc++.a: could not read
symbols: Bad value
Does your /usr/lib/gcc/x86_64-redhat-linux/4.4.1/ directory contain any files
or soft links with names starting "libstdc++.so"?  If soft-links, where do
they point to?  You can run these commands (replacing my 4.1.1 with 4.4.1 and
adjust the number after the .so as necessary) and compare their output to
mine:
tux% file /usr/lib/gcc/x86_64-redhat-linux/4.1.1/libstdc++.so
/usr/lib/gcc/x86_64-redhat-linux/4.1.1/libstdc++.so: symbolic link to
`../../../../lib64/libstdc++.so.6.0.8'
tux% file /usr/lib64/libstdc++.so.6.0.8
/usr/lib64/libstdc++.so.6.0.8: ELF 64-bit LSB shared object, AMD x86-64,
version 1 (SYSV), stripped
My machine tux is a RHEL5 64-bit system and has two separate RPMs which are
relevant to this issue:
tux% rpm -qf /usr/lib/gcc/x86_64-redhat-linux/4.1.1/libstdc++.so
gcc-c++-4.1.2-46.el5
tux% rpm -qf /usr/lib64/libstdc++.so.6.0.8
libstdc++-4.1.2-46.el5
I suspect you are missing the .so file completely, in which case you'll need
to install the FC11 versions of one or more of the above packages.
- Andrew
Epics Base 3.14.9 compilation errors for Fedora 11 64 bit version Ramu Denduluri
Re: Epics Base 3.14.9 compilation errors for Fedora 11 64 bit version Andrew Johnson
Prev: marccd driver Song, Jinhu
Next: Re: Epics Base 3.14.9 compilation errors for Fedora 11 64 bit version Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Epics Base 3.14.9 compilation errors for Fedora 11 64 bit version Andrew Johnson
Next: marccd driver Song, Jinhu
