I compiled areaDetector drvier (1-4) for marccd but it crashed right after it started. The precompiled executable crashed the same way.
The environment:
uname -a:
Linux cls1jin 2.6.23.1-42.fc8 #1 SMP Tue Oct 30 13:55:12 EDT 2007 i686 athlon i386 GNU/Linux
libc.so->libc-2.7.so
Marccd gave warning when it started: frameshift license invalid or expired and is disabled.
I tried to comment out the code reading and writing about frameshift. It only delayed the crash a little bit.
Some modules in the environment are newer than the required:
BUSY 1-2 not 1-1
SSCAN 2-6-4 not 2-6-3
MCA 6-11 not 6-10
Thanks in adance for your help,
Jinhu
The crash:
../../bin/linux-x86/marCCDApp < short.cmd
epics> < envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocMARCCD")
epicsEnvSet("TOP","/usr/local/src/epics-extras-3_14_10-20100210_172337/synApps-5_4_1/support/areaDetector/1-4")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
epicsEnvSet("SNCSEQ","/usr/local/epics/extra/synApps-5_4_1/support/seq/2-0-12")
epicsEnvSet("ASYN","/usr/local/epics/extra/synApps-5_4_1/support/asyn/4-10")
epicsEnvSet("AREA_DETECTOR","/usr/local/epics/extra/synApps-5_4_1/support/areaDetector/1-4")
epicsEnvSet("CALC","/usr/local/epics/extra/synApps-5_4_1/support/calc/2-7")
epicsEnvSet("SSCAN","/usr/local/epics/extra/synApps-5_4_1/support/sscan/2-6-4")
epicsEnvSet("AUTOSAVE","/usr/local/epics/extra/synApps-5_4_1/support/autosave/4-5")
epicsEnvSet("MCA","/usr/local/epics/extra/synApps-5_4_1/support/mca/6-11")
epicsEnvSet("gpib_DIR","/usr/local/lib")
epicsEnvSet("PCRE_LIB","/usr/local/lib")
epicsEnvSet("PCRE_INCLUDE","/usr/local/include")
epics> errlogInit(20000)
epics>
epics> dbLoadDatabase("$(AREA_DETECTOR)/dbd/marCCDApp.dbd")
epics> marCCDApp_registerRecordDeviceDriver(pdbbase)
epics>
epics> ###
epics> # Create the asyn port to talk to the MAR on port 2222
epics> drvAsynIPPortConfigure("marServer","172.17.11.21:2222")
epics> # Set the input and output terminators.
epics> asynOctetSetInputEos("marServer", 0, "\n")
epics> asynOctetSetOutputEos("marServer", 0, "\n")
epics> asynSetTraceMask("marServer",0,9)
epics> asynSetTraceIOMask("marServer",0,2)
epics>
epics> marCCDConfig("MAR", "marServer", 20, 200000000)
2010/02/23 13:44:20.703 172.17.11.21:2222 write 10
get_state\n
2010/02/23 13:44:20.716 172.17.11.21:2222 read 5
0x0\n\000
2010/02/23 13:44:20.716 172.17.11.21:2222 write 9
get_size\n
2010/02/23 13:44:20.726 172.17.11.21:2222 read 11
2048,2048\n\000
2010/02/23 13:44:20.726 172.17.11.21:2222 write 8
get_bin\n
2010/02/23 13:44:20.736 172.17.11.21:2222 read 5
2,2\n\000
epics> #marCCDConfig("MAR", "marServer", -1, -1)
epics> dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/ADBase.template", "P=13MARCCD1:,R=cam1:,PORT=MAR,ADDR=0,TIMEOUT=1")
epics> dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDFile.template","P=13MARCCD1:,R=cam1:,PORT=MAR,ADDR=0,TIMEOUT=1")
epics> dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/marCCD.template","P=13MARCCD1:,R=cam1:,PORT=MAR,ADDR=0,TIMEOUT=1,MARSERVER_PORT=marServer")
epics>
epics> iocInit()
Starting iocInit
## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
## EPICS Base built Feb 10 2010
13MARCCD1:cam1:MarReadStatus devAsynInt32::initCommon drvUserCreate ADDriver:drvUserCreate:, unknown drvInfo=MAR_READ_STATUS
2010/02/23 13:44:21.273 172.17.11.21:2222 write 12
set_bin,2,2\n
set_bin,2,2\n
2010/02/23 13:44:21.273 172.17.11.21:2222 write 9
get_size\n
epics>
epics> 2010/02/23 13:44:21.316 172.17.11.21:2222 read 11
2048,2048\n\000
2010/02/23 13:44:21.316 172.17.11.21:2222 write 8
get_bin\n
2010/02/23 13:44:21.326 172.17.11.21:2222 read 5
2,2\n\000
*** glibc detected *** ../../bin/linux-x86/marCCDApp: corrupted double-linked list: 0x0896d4b0 ***
======= Backtrace: =========
/lib/libc.so.6[0x86ed5d]
/lib/libc.so.6[0x870d8d]
/lib/libc.so.6(__libc_calloc+0x8a)[0x87289a]
../../bin/linux-x86/marCCDApp[0x81ab8a2]
../../bin/linux-x86/marCCDApp[0x813f73f]
../../bin/linux-x86/marCCDApp(cast_server+0x366)[0x8142f46]
../../bin/linux-x86/marCCDApp[0x81c297b]
/lib/libpthread.so.0[0x99950b]
/lib/libc.so.6(clone+0x5e)[0x8dab2e]
======= Memory map: ========
00110000-00111000 r-xp 00110000 00:00 0 [vdso]
00111000-001f1000 r-xp 00000000 fd:00 29883698 /usr/lib/libstdc++.so.6.0.8
001f1000-001f5000 r-xp 000df000 fd:00 29883698 /usr/lib/libstdc++.so.6.0.8
001f5000-001f6000 rwxp 000e3000 fd:00 29883698 /usr/lib/libstdc++.so.6.0.8
001f6000-001fc000 rwxp 001f6000 00:00 0
001fc000-00206000 r-xp 00000000 fd:00 3932268 /lib/libnss_files-2.7.so
00206000-00207000 r-xp 00009000 fd:00 3932268 /lib/libnss_files-2.7.so
00207000-00208000 rwxp 0000a000 fd:00 3932268 /lib/libnss_files-2.7.so
00796000-007c6000 r-xp 00000000 fd:00 29861952 /usr/lib/libreadline.so.5.2
007c6000-007ca000 rwxp 00030000 fd:00 29861952 /usr/lib/libreadline.so.5.2
007ca000-007cb000 rwxp 007ca000 00:00 0
007e8000-00803000 r-xp 00000000 fd:00 3932360 /lib/ld-2.7.so
00803000-00804000 r-xp 0001a000 fd:00 3932360 /lib/ld-2.7.so
00804000-00805000 rwxp 0001b000 fd:00 3932360 /lib/ld-2.7.so
00807000-0095a000 r-xp 00000000 fd:00 3935108 /lib/libc-2.7.so
0095a000-0095c000 r-xp 00153000 fd:00 3935108 /lib/libc-2.7.so
0095c000-0095d000 rwxp 00155000 fd:00 3935108 /lib/libc-2.7.so
0095d000-00960000 rwxp 0095d000 00:00 0
00962000-00989000 r-xp 00000000 fd:00 3935109 /lib/libm-2.7.so
00989000-0098a000 r-xp 00026000 fd:00 3935109 /lib/libm-2.7.so
0098a000-0098b000 rwxp 00027000 fd:00 3935109 /lib/libm-2.7.so
0098d000-00990000 r-xp 00000000 fd:00 3935111 /lib/libdl-2.7.so
00990000-00991000 r-xp 00002000 fd:00 3935111 /lib/libdl-2.7.so
00991000-00992000 rwxp 00003000 fd:00 3935111 /lib/libdl-2.7.so
00994000-009a9000 r-xp 00000000 fd:00 3935114 /lib/libpthread-2.7.so
009a9000-009aa000 r-xp 00014000 fd:00 3935114 /lib/libpthread-2.7.so
009aa000-009ab000 rwxp 00015000 fd:00 3935114 /lib/libpthread-2.7.so
009ab000-009ad000 rwxp 009ab000 00:00 0
00ab5000-00abc000 r-xp 00000000 fd:00 3935121 /lib/librt-2.7.so
00abc000-00abd000 r-xp 00007000 fd:00 3935121 /lib/librt-2.7.so
00abd000-00abe000 rwxp 00008000 fd:00 3935121 /lib/librt-2.7.so
00d8a000-00d95000 r-xp 00000000 fd:00 3935116 /lib/libgcc_s-4.1.2-20070925.so.1
00d95000-00d96000 rwxp 0000a000 fd:00 3935116 /lib/libgcc_s-4.1.2-20070925.so.1
0711b000-07130000 r-xp 00000000 fd:00 3935129 /lib/libtinfo.so.5.6
07130000-07133000 rwxp 00014000 fd:00 3935129 /lib/libtinfo.so.5.6
07183000-071a3000 r-xp 00000000 fd:00 3932335 /lib/libncurses.so.5.6
071a3000-071a4000 rwxp 00020000 fd:00 3932335 /lib/libncurses.so.5.6
08048000-08277000 r-xp 00000000 fd:00 31555824 /usr/local/src/epics-extras-3_14_10-20100210_172337/synApps-5_4_1/support/areaDetector/1-4/bin/linux-x86/marCCDApp
08277000-08282000 rw-p 0022f000 fd:00 31555824 /usr/local/src/epics-extras-3_14_10-20100210_172337/synApps-5_4_1/support/areaDetector/1-4/bin/linux-x86/marCCDApp
08282000-08289000 rw-p 08282000 00:00 0
08856000-08982000 rw-p 08856000 00:00 0
b527f000-b5280000 ---p b527f000 00:00 0
b5280000-b5329000 rw-p b5280000 00:00 0
b5329000-b5400000 ---p b5329000 00:00 0
b5422000-b5423000 ---p b5422000 00:00 0
b5423000-b5463000 rw-p b5423000 00:00 0
b5463000-b5464000 ---p b5463000 00:00 0
b5464000-b54a4000 rw-p b5464000 00:00 0
b54a4000-b54a5000 ---p b54a4000 00:00 0
b54a5000-b54c5000 rw-p b54a5000 00:00 0
b54c5000-b54c6000 ---p b54c5000 00:00 0
b54c6000-b5506000 rw-p b54c6000 00:00 0
b5506000-b5507000 ---p b5506000 00:00 0
b5507000-b5587000 rw-p b5507000 00:00 0
b5587000-b5588000 ---p b5587000 00:00 0
b5588000-b5608000 rw-p b5588000 00:00 0
b5608000-b5609000 ---p b5608000 00:00 0
b5609000-b5689000 rw-p b5609000 00:00 0
b5689000-b568a000 ---p b5689000 00:00 0
b568a000-b570a000 rw-p b568a000 00:00 0
b570a000-b570b000 ---p b570a000 00:00 0
b570b000-b578b000 rw-p b570b000 00:00 0
b578b000-b578c000 ---p b578b000 00:00 0
b578c000-b580c000 rw-p b578c000 00:00 0
b580c000-b580d000 ---p b580c000 00:00 0
b580d000-b588d000 rw-p b580d000 00:00 0
b588d000-b588e000 ---p b588d000 00:00 0
b588e000-b590e000 rw-p b588e000 00:00 0
b590e000-b590f000 ---p b590e000 00:00 0
b590f000-b598f000 rw-p b590f000 00:00 0
b598f000-b5990000 ---p b598f000 00:00 0
b5990000-b5a10000 rw-p b5990000 00:00 0
b5a10000-b5a11000 ---p b5a10000 00:00 0
b5a11000-b5a91000 rw-p b5a11000 00:00 0
b5a91000-b5a92000 ---p b5a91000 00:00 0
b5a92000-b5b12000 rw-p b5a92000 00:00 0
b5b12000-b5b13000 ---p b5b12000 00:00 0
b5b13000-b5b53000 rw-p b5b13000 00:00 0
b5b53000-b5b54000 ---p b5b53000 00:00 0
b5b54000-b5b94000 rw-p b5b54000 00:00 0
b5b94000-b5b95000 ---p b5b94000 00:00 0
b5b95000-b7bd6000 rw-p b5b95000 00:00 0
b7bd6000-b7bd7000 ---p b7bd6000 00:00 0
b7bd7000-b7c17000 rw-p b7bd7000 00:00 0
b7c17000-b7c18000 ---p b7c17000 00:00 0
b7c18000-b7c58000 rw-p b7c18000 00:00 0
b7c58000-b7c59000 ---p b7c58000 00:00 0
b7c59000-b7c79000 rw-p b7c59000 00:00 0
b7c79000-b7c7a000 ---p b7c79000 00:00 0
b7c7a000-b7cba000 rw-p b7c7a000 00:00 0
b7cba000-b7cbb000 ---p b7cba000 00:00 0
b7cbb000-b7cfb000 rw-p b7cbb000 00:00 0
b7cfb000-b7cfc000 ---p b7cfb000 00:00 0
b7cfc000-b7d1c000 rw-p b7cfc000 00:00 0
b7d1c000-b7f1c000 r--p 00000000 fd:00 29855418 /usr/lib/locale/locale-archive
b7f1c000-b7f1f000 rw-p b7f1c000 00:00 0
b7f2b000-b7f32000 r--s 00000000 fd:00 29950217 /usr/lib/gconv/gconv-modules.cache
b7f32000-b7f34000 rw-p b7f32000 00:00 0
bfed3000-bfee8000 rw-p bffea000 00:00 0 [stack]
Abort
- RE: marccd driver Mark Rivers
Epics Base 3.14.9 compilation errors for Fedora 11 64 bit version Ramu Denduluri
Re: Epics Base 3.14.9 compilation errors for Fedora 11 64 bit version Ramu Denduluri
<2010>
<2010>
